Well finally drove my GT today got it up to temperature and went to give it a boot and i have no boost atall :( I have a hybrid external wastegated td05 all the intercooler hoses are on and tight, im not running a boost controller yet just the 0.8 spring and im getting nothing ? were does the hose from the turbo go on the turbosmart wastgate top or bottom thanks any help will be great.
Only other things I can think of is wastegate stuck open, bov stuck open, badly cracked inlet or exhaust manifold, badly worn gaskets. Obviously most things would just cause more lag but just trying to help.
Yeah it would eliminate that being the cause but doubtful that it is. Have you double checked all intercooler piping for holes and silicone hoses for damage? Could also be if the pipes don't line up correctly at the joints.
I think you can connect the ewg to a compressor and put a pressure into it greater than spring pressure to test not sure though maybe someone could confirm
Yeah I would of thought so that's why I asked 1st if it was spinning freely. If you could maybe take the air filter piping off and start the car and check to see if it spins or not.
right had a look at it today and the turbo spins freely, i blocked the dump valve off and still no boost and ive took the wastegate off and put it on a compressor and it seems to move fine any other ideas :/
Don't have any other idea's unless a vacuum leak somewhere would cause it. Maybe best to double check exhaust and inlet manifolds and also boost pipes. You could do a leak test on the intercooler pipes to better check for leaks.
Not sure what's the best way to do it, you would possibly need something that fits over your intercooler piping that has a connection for an air compressor hose at the other end and put 'x' amount of pressure into the piping (making sure its sealed off at the other end somehow) and see if it reduces in pressure over time and if so how fast. Either that or you could use some kind of smoke and see if it escapes out at any of the joints or that.
ok mate thanks for your help
theres no sensors or anything i have to unplug changing from internal to external wastegate or something silly like that is there
Nope.
I would reckon it's most likely a vacuum leak somewhere, is all the intercooler piping ok. Can you hear the turbo spooling at all?
