  • 4 months later...
just spoke to jerrick and apparently the new batch of 4wd coilies have been reworked to sit lower so they should be sound now.
this was as low as my old one would go with the 4wd meisters back in 2012. im assured by jerrick that the new ones will allow the rears to sit the same as the fronts are in this pic.
This is browner's 85 on the latest revision, decked but they will drop a bit more when settled in and also he's on 14's
If I took off one locking ring or used a shorter spring then they could go lower but that's as low as they will go with envy thing compressed down fully
They will drop a bit as they settle in as Shorty has said
Plus that's just the rears maxed out the front Coilovers still have loads of adjustment to go lower if needed
Do you think in theory you could fit the old top mount to the meister rears? As that lifts the shock into the rear of the car and gives an extra 40mm of drop if it will fit them?
lol to be honest they might be busy but thats no excuse jerrick just dont seem bothered about anything lol.
then u got keri at WMS that takes ten years to reply to a PM
Heres mine on bc coilovers at the lowest setting
Still a bit too high, but lower than i thought it would go. Im quite happy with that! Eager to see how the miesters sit
IMO that's just right. Not to high or to low.
