gnome1 Posted April 23, 2012 Posted April 23, 2012 getting my exhaust made up on friday and was gonna buy a zisco screamer de-cat too, my car just runs a standard ct9 with a fmic and a cone filter, what problems could i run into with having a screamer fitted? or would it be fine? cant be arsed with hitting fuel cut. Quote
Louis Posted April 23, 2012 Posted April 23, 2012 (edited) just get a boost guage and keep your eye on it in hight revs and youll be fine for now but will need a HKS adjustable actuator to solve the problem but it will hit fuel cut for sure, mine did Edited April 23, 2012 by Louis Quote
gnome1 Posted April 23, 2012 Author Posted April 23, 2012 so a screamer will give me mega boost creep? so i was wrong thinking that it would help eliminate it. Quote
Amjad Posted April 23, 2012 Posted April 23, 2012 You will only eliminate creep if you get an externally gated setup Quote
Liam_D Posted April 23, 2012 Posted April 23, 2012 What Amjad said, if you run a screamer with externally wastegate it will control it perfectly.In my opinon running a screamer without a external wastegate is pointless. Quote
gnome1 Posted April 24, 2012 Author Posted April 24, 2012 it shouldnt cause mega boost creep though? i asked zisco performance the question and this is what they said :"No it will be absolutely fine running a screamer pipe on CT9 turbo. In fact we only sell screamer pipes for CT9 turbos as they go very well with them. The brace will bolt onto the same points where the stock cat was. The sound it makes when the car is on boost is great".: Quote
pick1 Posted April 24, 2012 Posted April 24, 2012 With your mods fmic, air filter, n screamer etc is almost guarantee u will hit fuel cut I started hitting it pretty much as soon as a I fitted my de-cat and exhaust u can either fit an hks adjustable actuator to try n control it or an ebc would be the best bet mate if u want to stay with the set up u got now Quote
Louis Posted April 24, 2012 Posted April 24, 2012 Plus screamer pipes on internally gated turbo's sound absolutely horrible they never seal fully anyway so your wasting your money, just get externally gated like everyone else says Quote
gnome1 Posted April 24, 2012 Author Posted April 24, 2012 i know what boost creep is and what causes it on turbo'd cars, im just new to starlets. I take it as soon as u decat a starlet the boost will creep dramatically and it will hit fuel cut? my mates starlets fine and he runs a blitz nur spec exhaust system with a j performance decat Quote
MARC MOSS Posted April 24, 2012 Posted April 24, 2012 My tongs gt spec hybrid with a nightpager doesn't creep at all! Maybe it would on a std ct9...And as for the noise I keep getting told how good it sounds , it does blow a bit until things warm up though that's true Quote
Louis Posted April 24, 2012 Posted April 24, 2012 (edited) My tongs gt spec hybrid with a nightpager doesn't creep at all! Maybe it would on a std ct9...And as for the noise I keep getting told how good it sounds , it does blow a bit until things warm up though that's trueTongs hybrids have bigger wastegate pennies and port though dont they?Thought that was a big plus point to getting one as you didnt get boost creep Edited April 24, 2012 by Louis Quote
gnome1 Posted April 24, 2012 Author Posted April 24, 2012 on high boost a starlet is 9psi which is nearly 0.7 BAR i think, fuel cut is 13psi which is just roughly 0.8 BAR, surely a decat with a fmic wont make it creep up nearly a BAR, or is it defo going to happen? Quote
pick1 Posted April 24, 2012 Posted April 24, 2012 If that's the route u defo wanna take then it's a case of suck it and see mate it either will or won't hit fuel cut and then u can make your decisions from there mate Quote
Hawaiiviper Posted April 24, 2012 Posted April 24, 2012 Before I had my electronic boost controller tuned right I've seen a boost creep of 1.92bar on my hybrid and was like WTF!!!. After getting the power fc and sorting the controller i have no creep w/ the hybrid actuator fmic and full exhaust. But im sure thats the power fc doing it's job. Quote
Louis Posted April 24, 2012 Posted April 24, 2012 (edited) My spec when i had the NightPager Decat was:-RX7 TMICApexi air filter cone5Zigen cat-backBoost restriction removalAnd obviously the night pager screamer/decatWith this spec it hit fuel cut in high revsIt creeped up to 11PSI when the factory cat was still fitted though Edited April 24, 2012 by Louis Quote
Amjad Posted April 24, 2012 Posted April 24, 2012 (edited) My spec isFront mount filterHDi FMICDecatExhaustHKS Actuator @1barPorted maniPorted turboMine's ECUAnd it doesn't creep at all Edited April 24, 2012 by Amjad Quote
gnome1 Posted April 24, 2012 Author Posted April 24, 2012 gnome, take the advice of many owners who have experienced these cars.The wastegate on a stock CT9 is rather useless.The best way to stop it is run a small diameter de-cat. something like 2.25" would help, keep your OEM filter piping and also get a good quality actuator. This will help, but again, it doesn't solve the problems being the turbo wastegate. The only true way to solve it is replace the turbo or weld up the wastegate and then retro fit an external wastegate to control things.Im not asking what boost creep is i know what it is, i was just asking if anyone had run a screamer or a decat with roughy the same mods as me, the reason im asking is because i know the ct9s wastegates are small and i want to know if it will defo make me hit fuel cut? Because ive read alot of people on here say a decat will make it over boost and hit fuel cut. Im pretty new to the starlet scene so i thought id ask on here, but tbh im just gonna buy a decat fire it on and see what happens, i get no boost creep whatsoever with my filter and fmic so i doubt a decat will make meHit fuel cut, ive asked a few local people with close to standard starlets with exhausts and decats and they dont hit fuel cut so i dont see why mines will but hey ho im just a newbie Quote
WallaceGlanza Posted April 24, 2012 Posted April 24, 2012 There's not a definite answer whether it will creep and hit fuel cut or not, but doing breathing and exhaust mods will increase the response of the turbo and with the internal wastegate being so small it is likely it will creep but to what extent you can't be sure.Mine used to creep upto 1 bar plus easily and in the cold it was even worse with relocated filter, fmic, decat and full exhaust.As you say try it and see what happens. Quote
shabz92 Posted April 30, 2012 Posted April 30, 2012 hellow everyone im new to the glanza world I've had a starlet n/a before but a glanza is totally different my manifold are stock nd are leaking im gona replace them nd get a decat aswel my uestion is is it worth getn a decatmy modsapexi air filter5zigen exhaustits runs at 0.6 bar boost but creeps slitly ovany help will be good thnks Quote
pick1 Posted May 2, 2012 Posted May 2, 2012 Yes mate de-cats are a good mod if your looking for that little extra power and noise Quote
RossTRD Posted May 7, 2012 Posted May 7, 2012 Does this replace the decat? I haven't really looked into these but they sound great Quote
