m11xky Posted April 29, 2012 Posted April 29, 2012 was in M5 last night and had pretty bad wheel wobble from 55mph and above especially on acceleration. also get it at at low as 45 going round a corner. have had alignment wheels balanced a month ago.....what could it be!?steering wheel so wobbly and whole car shakes too!please help!Mike Quote
jimmymac101 Posted April 29, 2012 Posted April 29, 2012 when was the last time the wheel was off? about a month ago? tightened up fully? james Quote
m11xky Posted April 30, 2012 Author Posted April 30, 2012 I will double check them all today.....thanks for replieswill update here when done.Mike Quote
Jamie1st Posted April 30, 2012 Posted April 30, 2012 We had problems with my mates fiesta at one point, had the balancing done, checked lower arm bushes etc etc.Turned out that had tyre had lost its shape and had an egg shaped bit in it.New tyre and it's smooth as ote! Quote
StuDoc 72 Posted April 30, 2012 Posted April 30, 2012 As above knackered tyre or wheel bud. Even a tyre on a wheel that is not balanced wouldnt cause serious wobble unless the wheel is buckled also. Mine was really bad for this. Got new alloys straight out the wrapper what a difference. If you have them spun on a wheel balancer you can easily spot the offender. If its only 1 or 2 of the wheels get them all balanced and stick the buckled ones on the back until you have money for new wheels. Quote
m11xky Posted April 30, 2012 Author Posted April 30, 2012 ok, thanks guys....cant wait til its sorted...3hrs of wheel wobble does your head in big time! embarrassing with passengers also Mike Quote
m11xky Posted April 30, 2012 Author Posted April 30, 2012 what do I check driveshafts for? loose or bent etc? Mike Quote
mech5107 Posted April 30, 2012 Posted April 30, 2012 Bent axles, damaged cv joints, lost balance weights, etc... Quote
