hi, i have a balieys dump valve and ive been told they have a reputation for starting to leak or something, i was just wondering if this could have happened to mine because when my turbo boosts i hear a hissing noise which is quite loud and dissapears when i lift off and the dumpvalve releases the pressure, my mechanic freind checked all the boost pipes and couldnt find anything else that could be leaking so think it could be this, anyone have any advice?
thanks Stefan
there crap d/v mate i had 1 did the same thing changed to a hks ssqv problem solved
X2 I bought the car with a baileys dv. It was leaking quite a lot at the time.
Replaced it with a spare baileys that worked fine but soon after bought an SSQV :D
1000000x better!
  • 2 weeks later...
crap unless if you replace the plastic piston inside with a metal one which can hold thicker rubber seals and also change the spring to a stiffer one.
