DanGEP91 Posted June 11, 2012 Posted June 11, 2012 (edited) Hey all - probably a completely retarded question, but I don't know the answer nonetheless. My glanza is rocking a basic open diff unfortunately and I was wondering if an aftermarket LSD can be fitted to this gearbox? Or would it be a cheaper option just to try and find an LSD box? Edited June 11, 2012 by DanGEP91 Quote
TrisK Posted June 11, 2012 Posted June 11, 2012 you can fit a dif to the box, taggy has done a guide/>http://www.ukstarletclub.com/forums/index.php?app=ccs&module=pages§ion=pages&id=2&record=39as to which is easier to come accross or cheaper i dont know.With us living where we do Dan shipping on a box could be expensive Quote
Jamie1st Posted June 11, 2012 Posted June 11, 2012 Fit an aftermarket lsd to your standard box, if you get an optional extra lsd box you will also need to change your drive shafts, which doesnt need to be done when fitting an aftermaket to the standard. Quote
TrisK Posted June 11, 2012 Posted June 11, 2012 Fit an aftermarket lsd to your standard box, if you get an optional extra lsd box you will also need to change your drive shafts, which doesnt need to be done when fitting an aftermaket to the standard.you only need to change one driveshaft i think jamie Quote
DanGEP91 Posted June 11, 2012 Author Posted June 11, 2012 Plenty of experience changing driveshafts though lol - either way I feel I now need an LSD Quote
mattyD Posted June 11, 2012 Posted June 11, 2012 i think if you were to get the factory lsd box you only need a different drivers side drive shaft but if you can afford it get an lsd fitted in your box Quote
akyakapotter Posted June 11, 2012 Posted June 11, 2012 Don't forget if you get a standard LSD box you got to change the rear gearbox mouth as its different Quote
rinseep82 Posted June 11, 2012 Posted June 11, 2012 (edited) I have a aftermarket lsd in mine saves changing the driveshafts you can choose what diff u would like aswell Edited June 11, 2012 by rinseep82 Quote
lugzy clart Posted June 11, 2012 Posted June 11, 2012 if u get a standard lsd box u dont know what condition the box will be in untill u fit it :/ i had a aftermarket 1 fitted n it was worth every pennie quaife ftw Quote
