hazell ep91 sr Posted June 17, 2012 Posted June 17, 2012 got a gt turbo engine for my engine conversion, i know some sensors need to be changed over to glanza ones in order for it to work with glanza loom, as far as i remember some sensors on inlet manifold? cheers harry Quote
bucketep91 Posted June 18, 2012 Posted June 18, 2012 Only 1 ive found thats different so far is the 1 on thermostat housing Quote
hazell ep91 sr Posted July 7, 2012 Author Posted July 7, 2012 anyone confirm this? i know the throttle position sensor is different. got one of those so desperatley after thermostat housing sensor! Quote
ryan lang Posted July 7, 2012 Posted July 7, 2012 why dont you just use the ep91 4efe thermo housing? they are the same as the 4efte thermo housings Quote
hazell ep91 sr Posted July 8, 2012 Author Posted July 8, 2012 Really? That's a lot easier, know if I could use the 4efe power steering pump too? As the pulley on the 4efte I have is buckled a beaut Quote
bucketep91 Posted July 8, 2012 Posted July 8, 2012 Im sure the thermo housings are different, would be easier buying a glanza 1. the power steering pump is different too but u could use the 4efe pulley if its just that thats bent Quote
hazell ep91 sr Posted July 8, 2012 Author Posted July 8, 2012 Ok cool beans, any ideas where I could pick up a glanza thermo sensor? Quote
bucketep91 Posted July 8, 2012 Posted July 8, 2012 Off a breaker? Put up a wanted thread or ask jay, he might have 1 Quote
_shaun_ Posted July 8, 2012 Posted July 8, 2012 idrees or jay are always the first port of call for spare parts Quote
sr reece Posted July 16, 2012 Posted July 16, 2012 I'm in the same position as you hazel we know so far that we need all the above sensors could someone confirm this for sure and also where the knock sensor is and what it's for and also where the thermostat housing is on the engine and am I right in saying the throttle position sensor is located on top of the inlet manifold where the throttle cable connects thanks any help is much appreciated Quote
