Bougourd117 Posted June 29, 2012 Posted June 29, 2012 Hey guys wander if anyone can help ive just fitted a brand new set of meister r coilovers to my Ep91 , and now under boost theres a clicking noise ... sometimes .. any ideas ? Quote
TrisK Posted June 29, 2012 Posted June 29, 2012 boost wont affect your suspension at all.is it affected by load? turning? bumps in the road?how loud is it? like a cv joint cracking? Quote
Bougourd117 Posted June 29, 2012 Author Posted June 29, 2012 its not like a CV joint cracking it almost sounds like something is vibrating . Quote
aidanep71 Posted June 29, 2012 Posted June 29, 2012 check your clearance between the coilover and your brake line bracket on the chassis mine was very tight to that Quote
ryan lang Posted June 29, 2012 Posted June 29, 2012 ^^ check the collarscheck the top mount bolts and alan keys are tight aswell dude Quote
jtaylor1990 Posted June 30, 2012 Posted June 30, 2012 I say check the brake line joint to the unit as mine were rediculously tight, once fitted they were fine though.Do u get the when turning lock to lock or is it over bumpy surfaces in a straight line. Could be unrelated to the coileys, I.E could be the ball joints mate Quote
TrisK Posted June 30, 2012 Posted June 30, 2012 I think he found itWas brake lines as suggested by aiden Quote
Bougourd117 Posted July 1, 2012 Author Posted July 1, 2012 Yeh brake lines were rubbing but I've adjusted all the settings and it's now running sweet as a nut thanks for all the help guys Quote
