Hello stupid question but with out ripping the box out is there any easy way to check eg drive shafts lengths etc as pass side I have a very small shaft. I no most cars have one longer then the other :p
Any help much appriated
The drivers side drive shaft will be shorter if it's an OEM LSD, and you'll see a lump sticking out of the box where the drivers side shaft goes in.
Jack the car up and turn one wheel by hand, if the other wheel turns in the same direction then it has LSD.
