hazell ep91 sr Posted August 15, 2012 Posted August 15, 2012 Wondering why my car wasnt boosting and was sluggish. Only drove 40miles since doing the conversion and Just checked dv is full of oil and take it turbo is a goner? Already replaced it before i put engine in as one that came on it had shaft play and seals were gone after giving it to a friend and him realising the seals were fucked. What to do now? Quote
akyakapotter Posted August 15, 2012 Posted August 15, 2012 I have a ct9 you can purchase it was fine before I took it of very minimal shaft play has a cracked waste gate but it would get you out of shit pm me an offer Quote
hazell ep91 sr Posted August 15, 2012 Author Posted August 15, 2012 Would Just boost creep a bit then? Quote
akyakapotter Posted August 15, 2012 Posted August 15, 2012 Yeah mate it didnt do it very much only reason I took it off was cause I went td04 or I'd still be useing it. Quote
bucketep91 Posted August 15, 2012 Posted August 15, 2012 Youl have a hard time finding a ct9 that doesnt have a cracked wastegate tbh Quote
hazell ep91 sr Posted August 16, 2012 Author Posted August 16, 2012 Ok bud. This one didnt. But oil seals are fucked. Had no blue smoke so guessing it was just hotpipe side seal thats gone? I havr had no luck with This. And had to unplug fan when i got home as it wouldnt go off. Another problem to sort out. Keep my chin up i guess Quote
pick1 Posted August 16, 2012 Posted August 16, 2012 U have to bridge the loop to the fan with it now having no air-com I had to do the same when I took the air-con off my gt then it runs normal again Quote
hazell ep91 sr Posted August 16, 2012 Author Posted August 16, 2012 Ive already bridged it. Maybe Ive done it wrong? Quote
redz11 Posted August 16, 2012 Posted August 16, 2012 is it spitting oil from your rocker cover? what dv you got? Quote
hazell ep91 sr Posted August 16, 2012 Author Posted August 16, 2012 Nothing from rocker. And a hks one. Got no smoke from exhaust which is wierd? Maybe oil isnt getting into the inlet mani. Quote
