hazell ep91 sr Posted August 16, 2012 Share Posted August 16, 2012 Wondering how i would run without a dv with standard top mount. What would i do with the Hotpipe outlet for dv? Quote Link to post Share on other sites
Hawwy Posted August 16, 2012 Share Posted August 16, 2012 Leave the dv on there dont put vac to it or block vac iff. Thats what ive done Quote Link to post Share on other sites
hazell ep91 sr Posted August 17, 2012 Author Share Posted August 17, 2012 Ok thanks Quote Link to post Share on other sites
Socks Posted August 17, 2012 Share Posted August 17, 2012 That will leak, valve will open on boost...Take the DV completely off and blank the vaccum and pipe off with somthing... Seal the system... Quote Link to post Share on other sites
Hawwy Posted August 17, 2012 Share Posted August 17, 2012 Hmm something like? Quote Link to post Share on other sites
hazell ep91 sr Posted August 17, 2012 Author Share Posted August 17, 2012 Ok thanks. Any difference running with and without a dv? Quote Link to post Share on other sites
Taggy Posted August 17, 2012 Share Posted August 17, 2012 You car will chatter like a wood pigeon, instead of the usual woosh sound, sounds sick Quote Link to post Share on other sites
hazell ep91 sr Posted August 17, 2012 Author Share Posted August 17, 2012 Woop. Where does it chatter from? Quote Link to post Share on other sites
Foggy Posted August 17, 2012 Share Posted August 17, 2012 Its chatters from the wastegate. Not great for the turbo. Quote Link to post Share on other sites
akyakapotter Posted August 17, 2012 Share Posted August 17, 2012 its fine i chattered on my ct9 sounds awesome and chatter on my TD04 as have no where for the DV anyway im sure if it was bad the guys at TD would have told me when i had it mapped Quote Link to post Share on other sites
LukeSR Posted August 17, 2012 Share Posted August 17, 2012 Some people say its bad, others have run without DV's for ages and not had a problem. ;) Quote Link to post Share on other sites
Max9650 Posted August 17, 2012 Share Posted August 17, 2012 Some people say its bad, others have run without DV's for ages and not had a problem. ;) as above.. personally i wouldnt run without one as turbo cars are designed with DV's for a reason..just imo Quote Link to post Share on other sites
hazell ep91 sr Posted August 17, 2012 Author Share Posted August 17, 2012 Need a new turbo first as my dv was full of oil. Stupid oil seals! Any way of replacing oil seals? Quote Link to post Share on other sites
Max9650 Posted August 17, 2012 Share Posted August 17, 2012 i think you can send them off to be rebuilt, but its not overlly worth it as its not overly cheap Quote Link to post Share on other sites
hazell ep91 sr Posted August 17, 2012 Author Share Posted August 17, 2012 Ah ok. Not something you can do then? Seems such a waste of a turbo lol Quote Link to post Share on other sites
MARC MOSS Posted August 17, 2012 Share Posted August 17, 2012 Shouldnt really run ct9's without a dv or standard recirc as the compressor surge will drastically shorten the life expectancy, some may last yes but it's not good for them.Td series turbo's can handle it with no problems i understand Quote Link to post Share on other sites
