Plug and play ecu ........ please help
right i have a buddy club black box play and play ep82
running arounf .65 .7 bar boost
fmic
ported std exh manifold
de cat - exhaust
front filter conversion
so i plugged the ecu in and it runs
went for a drive its bogged down at first but seemed to sort its self out
but it seems completely different power curve, no power untill about 5500k revs , and its running a hotter exhaust temp
i think its running lean , so im going to get a fuel pressure regulator
what you guys think ?
Thanks
It should run more rich than before.
Did you let it idle for 15-20 mins to sort itself out?
I take it the buddy club p&ps work different to jam, blitz etc?
Edited by daniel_g
there sealed ecu's they cant be mapped, the fueling can be adjusted thats it.
and thats what i thought they should run richer :/
no i didnt. going to weld a lambda boss on the exhaust tomorrow and then wait for my new plugs and will see what the lambda is reading
all the plug and plays are different.. they were designed for different set ups.. the likes of the jam ecus need to be bedded in, normally takes up to 50miles or so for it to start fueling properly...
Disconnect it and plug it in again, this time letting it idle for 20 mins or so, take it for a gentle drive, building boost slowly and gradually after a few mins driving.
done this ^ on my zep ecu and shes pulling like a train in every gear! and i'm running a bar of boost!.
was she running ok on the standard ecu?
il give this a go , thanks
going to put a wideband in just to be sure :)
