Plug and play ecu ........ please help
right i have a buddy club black box play and play ep82
running arounf .65 .7 bar boost
fmic
ported std exh manifold
de cat - exhaust
front filter conversion
so i plugged the ecu in and it runs
went for a drive its bogged down at first but seemed to sort its self out
but it seems completely different power curve, no power untill about 5500k revs , and its running a hotter exhaust temp
i think its running lean , so im going to get a fuel pressure regulator
what you guys think ?
Thanks
there sealed ecu's they cant be mapped, the fueling can be adjusted thats it.
and thats what i thought they should run richer :/
no i didnt. going to weld a lambda boss on the exhaust tomorrow and then wait for my new plugs and will see what the lambda is reading
  On 9/8/2012 at 10:35 AM, Amjad said:
Disconnect it and plug it in again, this time letting it idle for 20 mins or so, take it for a gentle drive, building boost slowly and gradually after a few mins driving.
done this ^ on my zep ecu and shes pulling like a train in every gear! and i'm running a bar of boost!.
was she running ok on the standard ecu?
il give this a go , thanks
going to put a wideband in just to be sure :)
