Guest Enzo Posted June 20, 2007 Posted June 20, 2007 here are an abreviation of some technical terms.RR - rolling roada machine that measures the power of an engineMPG - Miles Per GallonEBC - electronic boost controllerMBC - manual boost controllerRRFPR - rising rate fuel pressure regulatora device used to adjust the pressure at which fuel goes into the engineDOHC - Dual Over head CamshaftSOHC - Single Over head CamshaftTMIC - top mount intercoolerFMIC - front mount intercoolerEGT - exhaust gas temperaturePCD - pitch circle diameterthe measurement through the wheel studs of a carAFR - air/fuel ratioEFI - electronic fuel injectionBOV - blowoff valveor more comonly known as the dump valveSLD - speed limit defendertakes away the speedcut from any import epFCD - fuel cut defendertakes away the fuel cut away from any turbo epHID - high intensity dischargelighting system found on prestigious brands- transmits a brighter light over halogen bulbsMANI - manifoldCR - compression ratioABS - anti-lock braking systemTPS - throttle position sensorTDC - Top Dead Centrea term in regards to cam gearsPSI - pounds per square incha measurement of boost along with barBCC - boost cut controllerBMCS - brake master cylinder stoppera device that clamps around the master cylinder to stop it from movingA/C - air conditioningECU - electronic control unitthe brain that runs an engineAFM - air flow meterEMS - engine management system in regards to full aftermarket non oem solutionsEPC - electronic parts catalogueAFR - air/fuel ratioMAP - manifold absolute pressure (sensor)ARB - anti roll bara bar that mounts to the rear that increases roll stiffness and quells understearOEM - Stands for Original Equipment from ManufacturerJDM - Stands for Japanese Domestic Market - products and equipment that were intended for the Japanese market.USDM - Stands for United States Domestic Market - products and equipment that were intended for the American market.SR - Stands for 'Sport Rally'LSD - Limited Slip DifferentialBHP - Brake Horse Powerpower at the flywheelWHP - Wheel Horse Powerpower at the wheels, this is a more accurate measureWOT - Wide Open ThrottleZenki - Early modelKouki - Facelift revised modelPAS - Power Assisted Steeringfeel free to add to the list and edit if you can think of any more Quote
Jozinobi Posted June 20, 2007 Posted June 20, 2007 This list needs to be arranged alphabetically bossley Joz Quote
Guest Enzo Posted June 20, 2007 Posted June 20, 2007 ok that makes sense il do that thanxcan you or anyone think of any more? Quote
Jozinobi Posted June 20, 2007 Posted June 20, 2007 I added the 3 at the bottom I think the rest of the team need to visit the Ikea Lounge a bit more often so they can see whats happening...Will keep an eye out for more abbreviations tho man.Joz Quote
Jozinobi Posted June 20, 2007 Posted June 20, 2007 aye man, even from time to time wouldnt hurt lol.I've added the pics u wanted in the n/a writeup u did.Check it bro. Let us know your thoughts.Joz Quote
Nanglebadger Posted June 21, 2007 Posted June 21, 2007 i check in here every time im on B) B) that list seems fairly concise to me, if i think of anymore i'll be sure to let u know tho!Phil. Quote
miracle411 Posted June 21, 2007 Posted June 21, 2007 how about FTW - For The Win?? Just kidding, of course! Quote
lobotomy Posted June 21, 2007 Posted June 21, 2007 Gee I thought LSD was Lysergic acid diethylamide I had a good text file I copied from a random site once -- it had more general terms in it too that cropped up.I have an idea -- see how you can link to actual posts within a thread? Well we could have a glossary at the top (in alphabetical order) like G has already -- but each abbreviation is itself a link to a post further down the thread for instance: This links to reply 2And where it links to has a more in depth (unless it's really straightforward) description??note: only prob I've found so far is it links into a new window, but I'm sure there's code to link it in the same window. Quote
Guest Enzo Posted June 21, 2007 Posted June 21, 2007 minted some input, sweet guys,@ Adrian thats a total idea thanx man Quote
Stevie B Posted June 21, 2007 Posted June 21, 2007 added a few, will add more but im going to sleeep now.S. Quote
Jozinobi Posted October 23, 2007 Posted October 23, 2007 Added WOT to the mix.Guys you seriously need to get in here (Ikea Lounge) more lol.Joz Quote
Jozinobi Posted October 24, 2007 Posted October 24, 2007 EMS & EPC added.Keep em coming guys.Joz Quote
