StarletMad Posted October 17, 2012 Share Posted October 17, 2012 (edited) Is this a common problem that anyone knows of?Any ideas or anyone had this befor?Thanks Edited October 20, 2012 by Jonophilpott Quote Link to post Share on other sites
morgey Posted October 17, 2012 Share Posted October 17, 2012 Is your heater matrix leaking? Have the plugs under the floor/car popped out? Are your door seals intact? Quote Link to post Share on other sites
markostarletturbo Posted October 18, 2012 Share Posted October 18, 2012 Does sound like heater matrix Quote Link to post Share on other sites
PaulStarletSR Posted October 18, 2012 Share Posted October 18, 2012 Im gettin this aswell but its because theres water runnin down the bay n thru 1 of the holes in the bulkhead because the SR is at an angle on stands after havin the glanza engine dropped in. The loom rubber duznt fit flush in 1 of the holes so thats where mine is cumin from, plus the usual condensation Quote Link to post Share on other sites
funny onion Posted October 18, 2012 Share Posted October 18, 2012 Mine does this. There's a hole on the bulkhead that the air con pipes used to go through that is usually the cause. Mines the scuttle panel I think though, had it off about a year ago and didn't get it back on properly Quote Link to post Share on other sites
Starbo Moorley Posted October 18, 2012 Share Posted October 18, 2012 Tigerseal the hole up, job done Quote Link to post Share on other sites
StarletMad Posted October 18, 2012 Author Share Posted October 18, 2012 I have got an open hole where my vacuums come in but its the one right below fuel filter wouldn't have though water would get in there :-\ Quote Link to post Share on other sites
Simon Posted October 18, 2012 Share Posted October 18, 2012 Mine does this. There's a hole on the bulkhead that the air con pipes used to go through that is usually the cause. Mines the scuttle panel I think though, had it off about a year ago and didn't get it back on properly If you remove the air con evaportaor from inside the car then you can get the bung from toyota for a none air con starlet and seal the hole neatly mine was under £3 for my Glanza. Quote Link to post Share on other sites
funny onion Posted October 18, 2012 Share Posted October 18, 2012 Yeah I got a bung from an na starlet at scrapyard Quote Link to post Share on other sites
StarletMad Posted October 18, 2012 Author Share Posted October 18, 2012 The water isn't coming in there guys just have a quick look. Carpet is drenched and stinks lol. I pulled aside the wiring in the kick panel and lifted that rubbery shit and the water is coming in between there and the bulkhead. :-\ Quote Link to post Share on other sites
Starbo Moorley Posted October 18, 2012 Share Posted October 18, 2012 Windscreen seal ? Quote Link to post Share on other sites
StarletMad Posted October 18, 2012 Author Share Posted October 18, 2012 Its happened quite suddenly like in the last couple of weeks and there's alot of water there today if it was windscreen seal would it not be a more gradual thing? Quote Link to post Share on other sites
Starbo Moorley Posted October 18, 2012 Share Posted October 18, 2012 Depends how bad a state its in Quote Link to post Share on other sites
morgey Posted October 18, 2012 Share Posted October 18, 2012 If it stink its most likely coolant, usually smells almost curry-ish check pipes around heater matrix and the matrix itself. Also whats your coolant level like? If it stink its most likely coolant, usually smells almost curry-ish check pipes around heater matrix and the matrix itself. Also whats your coolant level like? Quote Link to post Share on other sites
StarletMad Posted October 18, 2012 Author Share Posted October 18, 2012 Checked rad and its rammed to the top with water. Its more of a damp smell bro just a bit mouldyish lol. There was a trail of water coming from the mentioned above place not anywhere towards centre console im confuzzled !! Quote Link to post Share on other sites
StarletMad Posted October 20, 2012 Author Share Posted October 20, 2012 The water is running down directly behind the conduate... Quote Link to post Share on other sites
markostarletturbo Posted October 20, 2012 Share Posted October 20, 2012 http://www.toyotagtturbo.com/forums/showwiki.php?title=Heater+matrix+and+dash+removalHope this helps Quote Link to post Share on other sites
StarletMad Posted October 20, 2012 Author Share Posted October 20, 2012 Ahh only took it out a few weeks ago for flocking... guess here we go again lol Quote Link to post Share on other sites
MARC MOSS Posted October 20, 2012 Share Posted October 20, 2012 Sounds like the windscreen rubber or a bulkhead leak dude Quote Link to post Share on other sites
morgey Posted October 20, 2012 Share Posted October 20, 2012 Maybe the rubber for the door electrics Quote Link to post Share on other sites
StarletMad Posted October 20, 2012 Author Share Posted October 20, 2012 I dunno moooosh just gotta wait for little man to go for a sleep then i can get amoungst it and take dash out i guess. Quote Link to post Share on other sites
