Offsets and 8J wheels
When you roll your archs you need to use a heat gun and heat the metal and paint before rolling so you dont crack the paint anyway so heat up the plastic arch trim at the same time and when its hot enough it will bend with it
Have done one like this before as i work in a body shop :)
I'm going to be running 15x7 ET13, currently on 195/50 tyres which rub a little on the GT but it's only dropped about 35mm
I'm planning to lower it more on Meisters so I'm definitely going to need the arches rolling. And I don't want to run skinny stretched tyres as I want to use the car on track a fair bit!
camber is your friend then amjad
what tyres are you running at the moment?
