Lawless Posted November 2, 2012 Posted November 2, 2012 Ok so fitted some new wheels last night 4x100 et13 an the outside edge of the tyre is catching the wheel arch got 195 50 r15 tyres was wondering will putting a 195 45 15 on cure this problem or is there another way around this Quote
Fozzie Posted November 2, 2012 Posted November 2, 2012 (edited) A lower profile tyre would certainly help, although it still may not quite give you all the clearance you need. You could also consider a bit of negative camber and having your arches rolled (if you haven't had this done already).Raising the car slightly would also help, if you have collies that is? Edited November 2, 2012 by uberphil88 Quote
Lawless Posted November 2, 2012 Author Posted November 2, 2012 Don't have coilovers it's on standard springs and shocks there only rubbing when going over bumps and big dips which is why I was thinking lower profile tyre would cure this wanted a second opinion first Thanks Quote
Lawless Posted November 2, 2012 Author Posted November 2, 2012 Forgot to mention its only rubbing on the rears aswel :/ Quote
ali_legend Posted November 2, 2012 Posted November 2, 2012 I sold my rims to Amjad. They are et13 take a look at his piks he's got them on a gt and piks on his n/a Quote
Starbo Moorley Posted November 2, 2012 Posted November 2, 2012 Low pro tyres and roll the arches Quote
Fozzie Posted November 2, 2012 Posted November 2, 2012 Hmmm if you're still running all standard suspension then stiffened dampers would probably be a big help, as they'd stop the car dipping up and down so much over bumps. May want to consider as your next upgrade lol ;) Quote
snails ep91 Posted November 2, 2012 Posted November 2, 2012 also pics..id like to see what it looks like as im getting some low et wheels soon and would love to know the stance this gives..but like others have said coilovers, rolling arches and 45 tyres may help.i think will be the only as starlet dont take to low offest wheels without work. Quote
Starbo Moorley Posted November 2, 2012 Posted November 2, 2012 When i ran et10 16x8 with 195/40 front and 195/45 rear with rolled arches my backs still caught, just dialed in some camber upfront and they never caught Quote
Josh@TunerLifestyle Posted November 2, 2012 Posted November 2, 2012 roll arches, coilovers, panhard rod, you will still get a little rubbing but if you do all these with 195/45/15's should just about clear it Quote
Lawless Posted November 2, 2012 Author Posted November 2, 2012 Hell of a lot of work then shame really got the rims cheap they look hench love the stance but can't take the rubbing ill go lower profile tyres first then Thanks for the advice aswel ;) Quote
Simon Posted November 2, 2012 Posted November 2, 2012 EP91 or EP82?The 91 will take a bit of a flare with a roll on the rear but you can't go too far due to the rear bumper mounting bracket but this can be trimmed back. Quote
Amjad Posted November 2, 2012 Posted November 2, 2012 Got any pics? They might be the same wheels as me hahaI'm planning to roll my GT arches and it will be having coilovers fitted, then probably will end up using 45 profiles Quote
Lawless Posted November 2, 2012 Author Posted November 2, 2012 No pics as of yet not sure how to upload there not the same as yours Amjad looked at your thread lol:D It's an ep82 so looks like rolled arches and low profiles it is then Anyone no a rough price on arch rolling Quote
Amjad Posted November 2, 2012 Posted November 2, 2012 Cool cool! Yea I got a price of about £150 from Arch EnemyI want mine pulled out as much as possible, if I can fit 50 profiles it'd be better as the tyres are cheaper but 45s do look a lot better Quote
Lawless Posted November 2, 2012 Author Posted November 2, 2012 Yea I'm trying to find somewhere local to Taunton to do mine turning out to be a bit of a mission tbh I think I'd only get the rear arches rolled ATM because the fronts don't rub at all was that price on fronts and back Quote
Amjad Posted November 2, 2012 Posted November 2, 2012 Lucky! Mine rub on the front when going over bumps but that it on springs. On coilies it'll be a lot better with a bit of camber dialled in but still I'm probably going to get it all rolled as I want to be able to use the car on track to the limit! Quote
Lawless Posted November 2, 2012 Author Posted November 2, 2012 FairPlay ill try out some pictures of mine up later don't even no what make these wheels are just want to be able to carry more than a bag of sugar in the back and not fear every dip and bump in the road Quote
Fozzie Posted November 2, 2012 Posted November 2, 2012 I expect you could just try giving the local bodyshops a call, I'm sure plenty of them could do you an arch roll. You could try Auto Refinishers in Ilton on 01460 54228 , or Elite Auto Bodies in Ilminster is a really good bodyshop so you could just give him a call on 01460 54501 and ask Quote
Lawless Posted November 2, 2012 Author Posted November 2, 2012 Legend thanks ill ring around hope all this hassles worth it :/ Quote
Fozzie Posted November 2, 2012 Posted November 2, 2012 No worries buddy, there's a few more locally but I know those two are good Quote
Lawless Posted November 2, 2012 Author Posted November 2, 2012 Ha ha I was thinkin that myself but don't want them to Look fucked also found somewhere willing to do them but they tell me the rollers will probably damage my paint Quote
Starbo Moorley Posted November 2, 2012 Posted November 2, 2012 Heat up the arch/plastic from underneathand gently tap it out, youll be fine mate a few guys have done it on here ! One of them who actualy works at a bodyshop too but i cabt remember his username lol Quote
