I think you would struggle to do this for any real benifit as you would really only be doing this for looks which i would guess would mean a low offset wheel. Considering most people struggle with an 8J ET10 a 9J wheel would have to be ET20-35 and will still need quite a bit of work and will always be a compromise.
Simon think about it
A 9j at a reasonable offset it going to hit caliper, spring and probably bumper mounts points
A general rule for the starlets
6-7 you'll be ok
7 depends in the offset and tyre choice (probably arch work)
8 will require stretch and arch work (probably extended arches)
9s probably not gonna helm without serious work
