Chand Posted November 9, 2012 Posted November 9, 2012 Hi guys I'm running a forged 4e with various mods etc And a hybrid td05 which has not long ago been mapped at TD @1.37 bar hit 295.2bhp Which im happy enough with but considering other options I'm thinking about possibly raising my rev limit but unsure of what I would need to make my car still safe and reliable I've been looking at 265degree cams And adjustable pulliesJust wondered if anyone has done this already and could advise me As with higher lift cams means I could still hit same sort of power but with less boost which is a bonus Thanks chand Quote
Danb Posted November 9, 2012 Posted November 9, 2012 i know nick and mike are working hard on some new valve train bits due for release shortly which should help you alot.Also look into inlet manifolds aswell, Quote
Chand Posted November 9, 2012 Author Posted November 9, 2012 Yeah thanks mate Yeah I've been looking into custom built Inlets but to me that just don't look anything special lol I no there made for a reason Quote
H_D Posted November 9, 2012 Posted November 9, 2012 what sort of head work have u done so far...solid buckets and uprated springs should do the job alone, the stock intake mani is good for up to 350-400bhp Quote
Chand Posted November 9, 2012 Author Posted November 9, 2012 Head work I've had the exhaust and inlet ported and polished to the exhaust gasket size And when you say speak to socks what am I asking him lol Quote
mattyD Posted November 9, 2012 Posted November 9, 2012 It sounds as though you have done the most benificial part, have you up rated the valve springs and buckets? All that's left would really be bigger valves Quote
Chand Posted November 9, 2012 Author Posted November 9, 2012 I don't believe the springs are updated or buckets so that the next thing to be looking into? Rather than cams and pullies Quote
mattyD Posted November 9, 2012 Posted November 9, 2012 (edited) how deep are your pockets mate? if thats what you wana do, may aswell do it all at once while the engine is in bits ;) Edited November 9, 2012 by mattyD Quote
Chand Posted November 9, 2012 Author Posted November 9, 2012 Lol my good god here we go again lol Quote
mattyD Posted November 9, 2012 Posted November 9, 2012 lol, tell me about it mate!!!!If I were you, I would get an inlet, uprated valve springs, soild buckets and possibly have a look at the valves/guides aswell I know zisco do a kit but its the best part of £3k I think.........................not sure what you get though!!!Or speak to the guys at TD, they will set you right Quote
Chand Posted November 9, 2012 Author Posted November 9, 2012 My good god 3k :/ and I'm getting respray soon aswell lol Quote
AdamB Posted November 9, 2012 Posted November 9, 2012 (edited) No need to go raising the rev limit if the turbo isn't able to provide the power beyond x rpm. Best bet is to ask TD it if they see any scope by raising the rev limit. Although theres no harm in changing over to a stiffer valve spring and solid buckets Whats the current rev limit at as well? Stock 7200? Edited November 9, 2012 by AdamB Quote
Chand Posted November 9, 2012 Author Posted November 9, 2012 Mike at TD has already said my set up is good and he said I'd just leave it as it is I'm not making a decisions soon anyways just looking into costs and what other people have done or would advice Quote
mattyD Posted November 9, 2012 Posted November 9, 2012 what is it you want to achieve anyway bud if you dont mind me asking??? Quote
Chand Posted November 9, 2012 Author Posted November 9, 2012 I'd like to run the turbo setup I have but hit the same sort of power but on less boost So it's better round tracks Quote
AdamB Posted November 9, 2012 Posted November 9, 2012 My opinion would be to leave it if its not going to net you anymore power, you also have to take into account that the turbo will start to become un-efficient the higher up the rev range you go, so power could start to drop off quite rapidly, that said if you raise the rev limit you might be able to net a slightly longer powerband without dropping too much power. Quote
mattyD Posted November 9, 2012 Posted November 9, 2012 (edited) from what I have heard, there is a certain inlet coming out that has been tested and got the same power at 1.1 bar as the standard did with 1.4 bar.....................thats kinda sounds like the sorta thing your after then you wouldnt have to change the engine or change the rev limit which, as adamB said might not actually benifit you anywayplus just running the same power at less boost might not necessarily do you any favours, you have a big turbo on a small engine and they generally dont come alive until they have more pressure going through them so lag might be a problem.............. Edited November 9, 2012 by mattyD Quote
Chand Posted November 9, 2012 Author Posted November 9, 2012 Aww right ok well in that case the inlets sounds like it might be the option for me And lag... I might also be looking into anti-lag but I'd see what power and torque it made with possibly a new inlet and go from there Quote
AdamB Posted November 9, 2012 Posted November 9, 2012 (edited) Inlet sounds interesting Matt! It does sound as if decreasing spool time is what your after, you could look into water injection which will help you out slightly, raising the compression ratio or fiddle with the gear ratio's.Anti-lag is ok if you got good brakes as it takes away some of, if not all of engine braking, so there will be much more heat going into the brakes. Edited November 9, 2012 by AdamB Quote
Chand Posted November 9, 2012 Author Posted November 9, 2012 How excatly does water injection actually work and what do you need cause I've spoken to gy before who run it but didn't understand what it was or how it worked etc And I don't think il actually run anti-lag it was just an option as once I'm in boost my cars fully spooled through every gear But have been looking at a corolla 6speed possibly I've been looking into lots of options as you can tell just not made or making any decisions fast Quote
AdamB Posted November 9, 2012 Posted November 9, 2012 Water injection injects a fine mist of water into the inlet stream. There are a number of places you can put the jet, all have their advantages. Placing the jet before the turbo compressor cools the air going into the turbo, increasing its efficiency, allowing more boost without the added drawback of adding heat. As we know that compressing air induces heat into the charge. Placing the jet after the intercooler allows the air to be cooler before it goes into the engine, cooler air allows more ignition advance in the map, and this is where power is gained through ignition.There are many different WI systems out there, but ones which have safety parameters are the best ones to go for. Like having a water level sensor, there could be harm if your boosting the car and water is not injected! Quote
Chand Posted November 9, 2012 Author Posted November 9, 2012 That sounds fantastic are you running one your self? If so where have you injected yours in the system Quote
AdamB Posted November 9, 2012 Posted November 9, 2012 (edited) Not run one on a starlet, have run a cheapo system before on another engine. Was never dyno'd so never really got to see the true performance outcome from it. Best kits are probably the aquamist stuff tbh, been around for years and good quality products. Though they are not that cheap.My cheapo kit I made out of using a windscreen washer pump, and used the washer bottle as the reservoir, and had a brass jet located near the throttle body Only trouble I had was that the jet kept clogging up as I wasn't always using distilled water, so the chalk and other shit in the water was clogging the jet up and not providing sufficient, if any spray. Edited November 9, 2012 by AdamB Quote
mattyD Posted November 9, 2012 Posted November 9, 2012 That's does sound good mate, did you have it run automatically or via switch inside the car? Quote
