i have a knocking that i can feel through the floor pan, gets faster as you speed up and slower as you slow down, so its deffinatly speed related. if i dip the clutch it dosnt make a difference.
i have changed the gear box and driveshafts to no avail.
on the day the knocking started id had the rear tyre changed.
knocking started off fairly quiet.. but has got louder over time.
suggestions? i am STUMPED and its starting to get expensive :(
Can you feel the knock more than hear hear it? Is your steering wheel vibrating? Have you tried 2 diff wheels on the front to make sure its not the wheels or tyres?
cant feel anythin through the steering wheel.
also the knock is too distinct to be a bent wheel of un balanced tyre..
  • 2 months later...
Just for reference if anyone else has this problem.. Collapsed wheel bearing. Was causing sn eliptical movement in the hub which is what made the knocking noise..
