rob_bower Posted June 26, 2007 Posted June 26, 2007 my car has started making a funny noise when you put your fot down only for the first few second's then it stops again, ive only noticed when moving and when in 3rd or 4th it almost sounds like its comming from the gear box? but i might be mistaken, Could it just be that my gear box oil is low?? or could there be another explination???cheers Rob Quote
Mikey Jay Posted June 27, 2007 Posted June 27, 2007 Is it a rattling type noise?If so, is probably just the injectors working away, my Starlet did it too in those gears Quote
StarletRick Posted June 27, 2007 Posted June 27, 2007 what sort of noise is it? 4es can make all sorts of funny noises! Quote
rob_bower Posted June 27, 2007 Author Posted June 27, 2007 its a grind/knocking noise is deffinatly sound like its comming from the front and underneath. i will check gearbox oil level asap. Quote
Blue Icarian Wings Posted June 27, 2007 Posted June 27, 2007 I had a horrible rattling/scraping at certain rev's (2.25k) was a lose exhaust mani heat shield vibratingOpen the bonnet, push down on the heat shield with a screwdriver, rev the engine see if that stops noise, other wise work your way around the engine bay, won't find the prob if it's gearbox, but will help rule out other loose bits Quote
tr1cky Posted June 27, 2007 Posted June 27, 2007 will it make the noise when u rev it with car standing or only when driving? Quote
rob_bower Posted June 28, 2007 Author Posted June 28, 2007 will it make the noise when u rev it with car standing or only when driving?when in motion only!!! my car is making a selection of noises at the mo one of the front bushes has gone too but no one can give me a price on a set or individual!!!! Quote
