Ryan-11 Posted November 17, 2012 Posted November 17, 2012 As above, trying to find a thread about removing abs, i think it was started by sparky a few years ago, not sure if it will b on here? couldn't find anything searching Quote
Ryan-11 Posted November 17, 2012 Author Posted November 17, 2012 typical, as soon as i put this up i find it lol Quote
yaristurbo Posted November 17, 2012 Posted November 17, 2012 http://www.ukstarletowners.com/index.php?showtopic=39712 Quote
daniel_g Posted November 17, 2012 Posted November 17, 2012 I've just done this mate, well i removed the unit and lines. Not ordered the t pieces or braided lines yet. Quote
_shaun_ Posted November 17, 2012 Posted November 17, 2012 u can just buy the lines from a uk spec n/a rather than making your own Quote
daniel_g Posted November 17, 2012 Posted November 17, 2012 I was maybe gonna get lines from a non abs gt if theyd fit. Quote
Ryan-11 Posted November 17, 2012 Author Posted November 17, 2012 I was thinking about that Shaun, You removed urs? Quote
yaristurbo Posted November 17, 2012 Posted November 17, 2012 I'm making mine own now, just wondering what to do with the wiring Quote
Simon Posted November 17, 2012 Posted November 17, 2012 I've done it used the parts from toyota from a UK car. Anything you need to know or need pictures of just ask.I'm just on with removing the engine bay loom to sit and strip all the unwanted ABS wiring out of it. Quote
Ryan-11 Posted November 17, 2012 Author Posted November 17, 2012 Simon, what parts did you need? also pics would b great Quote
daniel_g Posted November 17, 2012 Posted November 17, 2012 As far as i can make out, You need two t pieces Bolt them to the bulkheadRun the existing two rear lines to one t pieceRun a braided line from that t piece to the master cylinderRun braided line from each front caliper to the other t pieceRun a braided line from that t piece to the master cylinderThen you just remove all unnecessary wires, the ABS control unit and since my dash clocks are out i may aswell take the bulb out. Quote
_shaun_ Posted November 17, 2012 Posted November 17, 2012 ive removed the abs system and all the wiring from the loom just need to order the pipes. idrees was gonna send me what was needed all the part numbers are highlighted in yellow. but waiting till the cars been sprayed. i spent ages looking for info then sicaln said he bought all the part numbers highlighted in yellow and sold them off to simon who confirmed they worked from memory simon iddy and trisk all done it this way seems easyer than arseing around making up your own pipes Quote
daniel_g Posted November 17, 2012 Posted November 17, 2012 Can i do it that way ^ on a gt ? Get all the relevant parts from a non abs one ?How much are all them brake pipes etc ? Quote
_shaun_ Posted November 17, 2012 Posted November 17, 2012 thats the engine diagram from a uk spec starlet so would need to try find one from a uk spec gt and double check but am sure if u could check the part numbers you would be fine. cant rember what iddy quoted me new but it was around 50quid am sure. Quote
Simon Posted November 18, 2012 Posted November 18, 2012 Thats correct Shaun thats all you need right there.Will get some pics later today Quote
daniel_g Posted November 18, 2012 Posted November 18, 2012 For a glanza thats all you need but is it the same story for a gt ?Someone must have done it to a gt. Quote
Ryan-11 Posted November 18, 2012 Author Posted November 18, 2012 cheers guys ill see about gettin them parts ordered up, Daniel id imagine it would be the same for a gt? Quote
Ryan-11 Posted November 18, 2012 Author Posted November 18, 2012 also is number 1 on the diagram just a t-piece? Quote
Ryan-11 Posted November 18, 2012 Author Posted November 18, 2012 so we just need that one t-piece and the rest are all lines? im gona have alook today when im up at my car Quote
