Hawwy Posted November 23, 2012 Share Posted November 23, 2012 Hi allMy car on idle smokes white smoke all time and even on boost, it had been set up by mike and nick it does not use oil nor does it use water. After i clean car and go for drive the whole back end gets covered in little black dots that just rub off?Why the white smoke what is it Quote Link to post Share on other sites
JayJ Posted November 23, 2012 Share Posted November 23, 2012 (edited) Could be turbo seals, valve stem seals or ringlands. :-/ Does it smoke from oil filler cap? Edited November 23, 2012 by JayJ Quote Link to post Share on other sites
pick1 Posted November 23, 2012 Share Posted November 23, 2012 The black spots will just be from it running slightly rich in my experience as the emanage only has so many fueling fields and adjustments I'm sure socks posted a pic of his drive after he had rev'd the car a few times and he had the black spots sut on his drive and ultimately while your driving it will get blow back from the aerodynamics and get on the back of your car think most people with white gt's and glanza's may say the same Quote Link to post Share on other sites
Azz Posted November 23, 2012 Share Posted November 23, 2012 The black spots will just be from it running slightly rich in my experience as the emanage only has so many fueling fields and adjustments I'm sure socks posted a pic of his drive after he had rev'd the car a few times and he had the black spots sut on his drive and ultimately while your driving it will get blow back from the aerodynamics and get on the back of your car think most people with white gt's and glanza's may say the sameHOLE IN 1 THERE MY FREIND ! Quote Link to post Share on other sites
Hawwy Posted November 23, 2012 Author Share Posted November 23, 2012 (edited) Also what about smoke it smells of fuel by the wayAnd thanks pick1 matey Edited November 23, 2012 by Hawwy Quote Link to post Share on other sites
pick1 Posted November 23, 2012 Share Posted November 23, 2012 It will do if it's running slightly rich i get white smoke when I first turn my gt on condensation I put it down to I wouldn't worry to much if it not using oil or water or acting weird just a few layers of wax on the arse end will make it easier to get the black spots off when u come to clean it @azz cheers dude nice to know I've picked stuff up along the way with owning one of these lol Quote Link to post Share on other sites
Hawwy Posted November 23, 2012 Author Share Posted November 23, 2012 It will do if it's running slightly rich i get white smoke when I first turn my gt on condensation I put it down to I wouldn't worry to much if it not using oil or water or acting weird just a few layers of wax on the arse end will make it easier to get the black spots off when u come to clean it @azz cheers dude nice to know I've picked stuff up along the way with owning one of these lolOkay do they still run a bit rich if mapped up properly like mine Quote Link to post Share on other sites
5T4R7ET N/A Posted November 23, 2012 Share Posted November 23, 2012 if its thick white smoke, then you need to be worried.otherwise it will be condensation, more noticable in winter Quote Link to post Share on other sites
Hawwy Posted November 23, 2012 Author Share Posted November 23, 2012 What would thick white smoke meanIts like the normal smoke that comes out of everybodys cars but just loads comes out Quote Link to post Share on other sites
pick1 Posted November 23, 2012 Share Posted November 23, 2012 Yes mate I'm on emanage Blue and mine still runs a little rich like I say they only have so many fueling fields and adjustments the emanage ultimate has more then when u go stand alone like wolf or power fc then the mapping fields are far superior and I can get a finer tune but if your worried give mike at TD a tinkle and ask his advice I have a white gt and after a spirited drive I get the black spots on mine Quote Link to post Share on other sites
Hawwy Posted November 23, 2012 Author Share Posted November 23, 2012 Okay mate mainly its the smoke thats bothering me as it quite a bit smells like fuel . Quote Link to post Share on other sites
Hawwy Posted November 24, 2012 Author Share Posted November 24, 2012 (edited) This is cold startAnd it was really cold and frosty morning/>http://i1282.photobucket.com/albums/a523/hawwyzz/DBDCCDCD-8617-407A-910D-9C9427D4FF69-931-00000071F0BE3F85.mp4An this is normal how it smokes all the time most the time when idling/>http://i1282.photobucket.com/albums/a523/hawwyzz/6FA2CDCD-B56A-4497-946B-0E4C73EE9371-931-00000072030FD414.mp4Links are videosCheers Edited November 24, 2012 by Hawwy Quote Link to post Share on other sites
james@cjperformance Posted November 24, 2012 Share Posted November 24, 2012 id say cold start is condensation in the exhaust and warm vid looks to be normal for this time of the year especially if its frosty. stick you tumble dryer tube out the window at the same time of day and you qill have the same affect thick white smoke usually indicates head gasket issues but if its not loaing or using any water id say its alright. just keep an eye on it Quote Link to post Share on other sites
steve-gers Posted November 24, 2012 Share Posted November 24, 2012 my car smokes white on startup but totally goes away once it is warmed up and has no smoke at all when idling warm. It is however using some water but I am putting this down to a very old radiator as it has been using a small amount of water since I bought it. Quote Link to post Share on other sites
Hawwy Posted November 24, 2012 Author Share Posted November 24, 2012 Okay cheers everyoneSteve mine still does it warm Quote Link to post Share on other sites
StarletMad Posted November 24, 2012 Share Posted November 24, 2012 Id defo say moisture looking at vids mine does this dont worry dude. Quote Link to post Share on other sites
Broony Posted November 26, 2012 Share Posted November 26, 2012 Id defo say moisture looking at vids mine does this dont worry dude.So does mine Quote Link to post Share on other sites
Dan507 Posted April 28, 2015 Share Posted April 28, 2015 BUMPgot this issue with my starlet. smoke's really baldly. don't do it straight away only once it's got boost going though it and when off boost it calms down but still smokes. compression is around 175psi across all 4, slight coolant leak from the head gasket area (external) Car stuggles to start, takes a while to get going, sometimes its lumpy. most of the time it idles fine. Turbo is a 'speedvision' hybrid that looks near enough new any help would be much appreciated. Quote Link to post Share on other sites
Calum122 Posted May 15, 2015 Share Posted May 15, 2015 Is there any oil in the intercooler pipework just off the turbo side, or anywhere? Even if it's got 175 PSI across the cylinders don't discount the Valve Stem Seals Also, disconnect the PCV valve from the intake and vent to atmosphere from the rocker (use some hose to stop oil gooing to the engine bay, preferably oil catch can) and block the inlet side off. The PCV can fail and let oil through. Quote Link to post Share on other sites
