im asking a question im sure has been asked before.
im looking to forge my 4efte i may have a set of new forged rods and pistons
  1. what else is truely needed
  2. what sort of cost will i be looking at
  3. and are there suggestion to do and not to do
before i start going mad i want to know the score really im looking to run a vf22 hybrid at around 1.6 to 1.8 bar max
please can i have some suggestions
thanks dave
Cross hatch and hone block.
Have Crank re-done and balanced.
Head Work.
New Injectors
Uprated ECU + Map
Bearings
Seals
If your looking for a quick cheap build then you can probably get it all in for £2k. For a build which will withstand any sort of punishment you'll probably be looking closer to £3k.
Hope the guide helps, prices for forged deals have dropped a little bit since i built mine, but yes dont expect to get much change from £2k!
well looking at it i think im going to start putting money aside and spend it once and with the right people im happy to wait for a lovely car as long as it comes in the end.
errrrm let me check, prices are without vat
Resurfacing the engine block (Decked) £56
Notching the block to accept 5e rods £75
Rebore oversize and cylinder hone block £104
Polish the crank £13
skim head £39
It's not cheap even if you do it your self. You need to factor in all the new service parts too, belts, pumps, plugs ect. Then all the running in mineral oil then the decent stuff after running it in, plus a handful of oil filters.
