Pretty sure all ep 82/91 suspension is interchangeable. Think the only difference is an ep 91 front top mount has 3 studs and 82 has 4 but the hole is there on the 91 strut turret so doesnt matter. Someone else can confirm though.
Spot on! Good work boys.....Rob H your gonna be my go to man lol....I'm looking at the Tein rear coil overs on eBay.....what do you think?
Personally I think the teins are too hard for our shitty roads I used to run HAs on the rear of mine but I thought they where too hard so I am running the stock SR TTE suspension now and sticking with it as long as I can! But it's each to there own when it comes to suspension.
Most jap coilovers are very harsh for uk roads. My tte springs were good till they snapped. 2 of the 4 :( then I had RSR springs on kyb shocks and they were a very good set up on the n/a. If money is no object or you don't mind saving get meisters, a huge improvement IMHO and I used to use it daily. Just as comfy as the shock spring combo just with more adjustability give it edge.
Edited by rob_bower
