Flynn Posted November 30, 2012 Share Posted November 30, 2012 Can anyone tell me if coil overs off a GT Turbo will fit my SR? Quote Link to post Share on other sites
StuDoc 72 Posted November 30, 2012 Share Posted November 30, 2012 Pretty sure all ep 82/91 suspension is interchangeable. Think the only difference is an ep 91 front top mount has 3 studs and 82 has 4 but the hole is there on the 91 strut turret so doesnt matter. Someone else can confirm though. Quote Link to post Share on other sites
Rob H@RCH Engineering Posted November 30, 2012 Share Posted November 30, 2012 Yep it will bolt straight on you just have to remove the plastic blanking plug on the front bolt hole on the front strut tops. Quote Link to post Share on other sites
rob_bower Posted November 30, 2012 Share Posted November 30, 2012 ^^^ this Quote Link to post Share on other sites
Flynn Posted November 30, 2012 Author Share Posted November 30, 2012 Spot on! Good work boys.....Rob H your gonna be my go to man lol....I'm looking at the Tein rear coil overs on eBay.....what do you think? Quote Link to post Share on other sites
Rob H@RCH Engineering Posted November 30, 2012 Share Posted November 30, 2012 Personally I think the teins are too hard for our shitty roads I used to run HAs on the rear of mine but I thought they where too hard so I am running the stock SR TTE suspension now and sticking with it as long as I can! But it's each to there own when it comes to suspension. Quote Link to post Share on other sites
rob_bower Posted November 30, 2012 Share Posted November 30, 2012 (edited) Most jap coilovers are very harsh for uk roads. My tte springs were good till they snapped. 2 of the 4 then I had RSR springs on kyb shocks and they were a very good set up on the n/a. If money is no object or you don't mind saving get meisters, a huge improvement IMHO and I used to use it daily. Just as comfy as the shock spring combo just with more adjustability give it edge. Edited November 30, 2012 by rob_bower Quote Link to post Share on other sites
Socks Posted December 1, 2012 Share Posted December 1, 2012 EP82 EP91 all interchange Quote Link to post Share on other sites
RicoW Posted December 1, 2012 Share Posted December 1, 2012 ep71 are also the same Quote Link to post Share on other sites
