Banbury Glanza Posted December 5, 2012 Posted December 5, 2012 I have a boost gauge in my car atm and have just got a two pod pillar pod just wondering what other gauge to get ? Is it just personal preference or do I need one more than another ? CheersTodd Quote
mattyD Posted December 5, 2012 Posted December 5, 2012 I would say........................oil pressuresurely your not stupid to give the car some when its cold so any temp gauges arent needed at this stage and oil pressure is very important Quote
Banbury Glanza Posted December 5, 2012 Author Posted December 5, 2012 Haha no not stupid enough lol :/ ok mate cheers Quote
mattyD Posted December 5, 2012 Posted December 5, 2012 (edited) or are you...................... what kind of make are you looking at? being an oil pressure gauge its quite important to have a decent one Edited December 5, 2012 by mattyD Quote
Liam_D Posted December 5, 2012 Posted December 5, 2012 I have boost, oil and water temp just to make sure its not getting too hard under hard driving. Hoping to get oil pressure when i manage to source a gauge Quote
Hawwy Posted December 5, 2012 Posted December 5, 2012 Thanks for thread i was wondering same too But do the oil /water temp gauges come with sensors must be hard to install sensors? Quote
Banbury Glanza Posted December 5, 2012 Author Posted December 5, 2012 Hahaha I'm looking at the STRI gauges from TD, but just looking about atm Quote
Wardy Posted December 5, 2012 Posted December 5, 2012 Ive just ordered oil temp, oil pressure and boost in bar. You will have to get a sandwich plate for your oil pressure and tempreture probes to connect into Quote
Banbury Glanza Posted December 5, 2012 Author Posted December 5, 2012 Ok cheers lads I will have a look for oil pressure gauges and plumbings lol Quote
Wardy Posted December 5, 2012 Posted December 5, 2012 I went for depo racing which im assured are a good make Quote
Amjad Posted December 5, 2012 Posted December 5, 2012 Depo FTW/>http://www.youtube.com/watch?v=0cmCZWe6C1A Quote
mattyD Posted December 5, 2012 Posted December 5, 2012 Hahaha I'm looking at the STRI gauges from TD, but just looking about atmOooooooooooooooo good choice sir, that what I have got With regards to fitting of the sensors, there is a way you can plumb them in to the engine itself! I shall try and find the thread.............A sandwich plate would probably be the easiest option though Quote
StarletMad Posted December 5, 2012 Posted December 5, 2012 Im sure theres adapters on fleebay that allow you to do this. Quote
Azz Posted December 5, 2012 Posted December 5, 2012 I have oil pressure, water temp, volts, oil temp, boost and boast controller depo gauges off cj performance, can't fault them at all and have a peak/warning. Quote
Hawwy Posted December 5, 2012 Posted December 5, 2012 Where is sandwich plate available and do u get the sensor with gauge or get seperately Quote
mattyD Posted December 5, 2012 Posted December 5, 2012 what do you mean where is sandwich plate??the sensors do come with the gauges indeed, well at least the ones I have had did Quote
Banbury Glanza Posted December 5, 2012 Author Posted December 5, 2012 Im sure theres adapters on fleebay that allow you to do this.Adapters for what ? Quote
Broony Posted December 5, 2012 Posted December 5, 2012 Oil temp as that's what you want up to temperature not just your water but if you can I would go boost, oil temp, oil pressure and water temp as the stock water gauge is gash! Quote
Hawwy Posted December 5, 2012 Posted December 5, 2012 Okay but how about water temp do they come with sensor and where it places Quote
Azz Posted December 5, 2012 Posted December 5, 2012 You need an adapter to fit into your radiator pipe mate that will sort water temp Quote
Hawwy Posted December 5, 2012 Posted December 5, 2012 Where can they be had?So need sandwich plateOil temp gauge that comes with sensorOil pressure sensor - where does this goSorry for thread hijack Quote
mattyD Posted December 5, 2012 Posted December 5, 2012 ^^what he saidand the sandwich plate places between you oil filter housing and oil filter Quote
Banbury Glanza Posted December 5, 2012 Author Posted December 5, 2012 Think I'm going to get oil pressure first Quote
