Dan_Henderson Posted December 7, 2012 Posted December 7, 2012 hi lads I've taken out the old radio and stared puttin in the new 1, i didnt have a harness so I've chopped off he plugs and soldered them together but i dont seem to be getting a live at the blue wire with yellow stripe and cant get the radio to work, all fuses seem ok, I've used grey(ignition) to Red , blue and yellow to yellow and black to black and radio wont power up Quote
StarletMad Posted December 7, 2012 Posted December 7, 2012 Get one from somewhere else then mate Quote
Dan_Henderson Posted December 7, 2012 Author Posted December 7, 2012 Does it have more then one fuse? Quote
ryan lang Posted December 7, 2012 Posted December 7, 2012 id have just got a harness, they are only like 6 quid arent they? Quote
Dan_Henderson Posted December 8, 2012 Author Posted December 8, 2012 Wish I did now mate but I've already cut into it, it must be a fuse because the clock and interior light isn't working either but the fuse under te steering wheel looks fine Quote
morgey Posted December 8, 2012 Posted December 8, 2012 fuses can look ok but actually be blown, if not sure, check it with a multi meter Quote
Dan_Henderson Posted December 10, 2012 Author Posted December 10, 2012 Is there any fuses in the engine bay that would my radio/clock/int light not work? Quote
morgey Posted December 10, 2012 Posted December 10, 2012 One called dome i think is something to do with interior but im not 100% sure Quote
_shaun_ Posted December 10, 2012 Posted December 10, 2012 the lesson here would be do it properly the first time and dont try pikey it.do you no for a fact the radio works? is it a brand new unit and have you choped the plugs off that aswell?the best way would be to just colour match all the wires and solder the plugs on and do it properly. Quote
Dan_Henderson Posted December 10, 2012 Author Posted December 10, 2012 its worked fine in other cars I've had, its not the connection im having problems with , im not getting a live and yes the HU works I've had it hooked up directly to a battery Quote
TrisK Posted December 10, 2012 Posted December 10, 2012 its worked fine in other cars I've had, its not the connection im having problems with , im not getting a live and yes the HU works I've had it hooked up directly to a batteryIs it perm live your missing? Or switched ignition?You could check the dome fuse as that does light, clock and radio iirc Quote
Dan_Henderson Posted December 10, 2012 Author Posted December 10, 2012 cheers mate, its the perm live missing mate Quote
Dan_Henderson Posted December 10, 2012 Author Posted December 10, 2012 cheers to those that helped, the wiring diagram i had said black was - but its infact brown that is - and the dome fuse was blown in the fuse box in the bayI now have a working head unit woop woop!! Quote
TrisK Posted December 10, 2012 Posted December 10, 2012 Can you post a correct one here? And for what year car? Quote
Dan_Henderson Posted December 10, 2012 Author Posted December 10, 2012 ill type one out soon mate Quote
