Sure it's just a bulb. P.s why are you in low turbo mode lol :D
Do you have a link of where to get the bulb and how I change it please mate ?
And I got told if I have a front mount intercoller then it doesn't matter ? But it's in low justnow because basically I'm a shitebag and don't want to run it full boost on these shite tires
to change it you need to take off the dial face mate,
remove all surrounding plastic
pull off speedo needle
unscrew dial face and pull it off
and the bulb shall be behind
not sure what they are though, cant remember off hand im afraid
having a front mount doesnt effect hi/low boost, do you know whether or not the hi/low boost solenoid has been removed?
Ok sounds pretty simple to me ? Just screws and stuff then ?
Hopefully someone on here knows what bulbs they are before I take it all apart ?
And eh I'm not sure I think it's still In how do I check ? And what difference does it make on high?
yeh its reasonably simple mate, that most difficult thing is putting the needle back on!
the first time I did it, it was a bit of a ball ache :( just remember at 3000rpm you should be reading 60mph, that how I knew I got it sitting properly again :)
do you have this in your engine bay??
You can take the whole cluster out so you don't fuck up the speedo dial and get to it from the back.
Just take the bulb to a motor factors and tell them you want the same.
Edited by DavidAshton
you can but what a fucker that is, lol
