Thought it would be good to find out what pressures people are running, and what handling characteristics they portray,
Tyres: Uniroyal Rainsport 2
Pressures Front/Rear: 32/32
Handling Mods: Tein Lowering springs, Front strut brace.
Car handles reasonably well, maybe slightly on the oversteery side.
Tyres: Goodyear eagle f1 GSD3s
Mods: coilovers, c pillar brace, rear upper brace. Rear arb, floor brace, front upper brace, fast road set up
I run them at 32 all round, handles beautifully couldn't ask for better handling
Tyres: Toyo proxies
Pressures: 33/33 ( I only do this as tyres loose approximately 1.2psi in the first 20 miles or so after being topped up) so runs around 32/32
Mods : Tein springs, oem front strut, oem rear strut
tyres: prada spec 2s
pressures: 30 rear 31 front
mods: tein mono flex, anti lift, arb 22mm front, adjustable rear on middle setting, cusco carbon struts, cusco lower arm bar, cusco 6point cage, trd diff, full polybush, race geometry set up
handles very well grips like crazy, tyre wear very even other then alote of wear to outside of passenger side tyres due to very hard cornering and too many roundabouts :)
very slight oversteer when wet, understeer when being brave when dry.
Edited by Dave D Glanza V
Tyres: Falken Ziex ZE-912
Pressures: 2.3Bar front - 2.3Bar Rear
Mods: Tein Type HA Driving master coilovers , front strutbar
Handles very good , very harsh over speedbumps tough.
Pressures Front/Rear: 35/34psi
Handling Mods: (EP91 NA) Meisters, Whiteline 24mm FARB, Whiteline fixed RARB, Whiteline ALK, OEM front brace, Cusco Rear Brace
I run slightly higher pressures to avg around 40mpg, but it still handles very very well.
Dropping them to 33/32 the handling is amazing for what the car is, but I can see the benefit that would be achieved by running tyres with a slightly harder sidewall (I believe the Rainsports have a soft wall the way they look quite flat usually!)
