Yet another question from me haha !
I'm getting a bucket seat for my Christmas (late present) and can I just get the omp, sparco subframe and bolt them into where the starlets seat rails bolt ? Like through the ground ?
Cheers
The bucket seat ? Na I'm going to the autos port show to buy one :) but the omp rails are universal and it makes the seat unmovable ? Like not adjustable but wiill the subframe a fit the bolts that are in the holes of the starlet ?
You'll need a starlet specific subframe that bolts to the floor and then custom side mounts making to bolt Upto that subframe.
Also it has to move for MOT purposes now, so you'll have to make it slide backwards and forwards.
I just made some up for my seats and charls recaros this weekend. Modified the Evo 4 rails that came with the seats. Just welded starlet feet on the rails.
Is there nothing I can buy from deamon tweaks or something to make it fit ?
I bought a universal recaro rail from demon tweaks,
then drill the rivets out the standard seat rails to get the feet off
All bolted together no welding required
Aw really ? Any chance of some pictures and stuff of the bits you bought ? As I'm going to the autosport show on Friday so need to get everything there ?
Did you need to drill any holes in the floor or anything ?
Nope and i cant get any as its ony my old glanza that sold.
basically, pick whichever is suitable for your seat
/>http://www.demon-tweeks.co.uk/motorsport/seat-mounting-frames
i went for
/>http://www.demon-tweeks.co.uk/motorsport/seat-mounting-frames/recaro-double-locking-runners
then take the standard seat out, take the seat off the rail.
flip the rail over, drill out the rivets/spot welds holding the feet on the rails.
using nuts and bolts, bolt the feet to the new rails.
when you hold it in the car its obvious which holes you use.
IIRC i had to drill out to extend one hole.
think thats it. or how it was for me atleast
dean at RW Developments can butcher and weld you some rails.mate
Who's that ? And how much ?
If I just drill the feet off my rails and bolt them onto the universal ones what size of bolts do I need ?
Yea but I will need to get them before I drill mine out because I won't have a car to go and get them ?
Anyone have a clue ?
Do the passenger seat first then ;)
And i think i used m10s
Passengers seat isn't getting done mate its only mine :)
And what length of m10 do I need ?
And do I need nuts or will the runners be threaded
I used nuts, and probably a handful of washers in some places.
