Banbury Glanza Posted January 14, 2013 Posted January 14, 2013 Hi mate all I know is the intake has been opened up and deristricted inside of compressor housing all fully smoothed and polished then external polish. Will give it greater flow and less lag. Hope this helps Quote
Browner Posted January 15, 2013 Posted January 15, 2013 So it's not a hybrid then just a polished stock td04 Quote
Banbury Glanza Posted January 15, 2013 Posted January 15, 2013 Pretty much mate polished and smoother and opened up so it's more free flowing. Quote
Lew91 Posted January 15, 2013 Posted January 15, 2013 Hi mate all I know is the intake has been opened up and deristricted inside of compressor housing all fully smoothed and polished then external polish. Will give it greater flow and less lag. Hope this helpsI could pretty much do that myself, I was under the impression the veins had been changed to. Quote
Banbury Glanza Posted January 15, 2013 Posted January 15, 2013 No mate I'm not sure why it was advitised as hybrid really. Just passing on what I know Quote
Starbuck Posted January 15, 2013 Posted January 15, 2013 Bradp amend the title please to avoid confusion. Cheers Quote
Browner Posted January 15, 2013 Posted January 15, 2013 "shiny td04 for sale" lolSo does he want £40 for it or what Quote
pick1 Posted January 15, 2013 Posted January 15, 2013 ^^^ u can only presume so if its standard I've pm'd him Quote
bradp94 Posted January 15, 2013 Author Posted January 15, 2013 The word "hybrid" means a mixture of two or more elements to make one thing. This has been open up and polished which are two separate processes making the one object different. Therefore it is hybrid but not as you all presumed. Quote
Browner Posted January 15, 2013 Posted January 15, 2013 A hybrid turbo is mating two different turbos together to improve spool up, top end pull etc etc. Basically using the best elements of both turbos to make one really good one. Pulling a turbo apart and reassembling it does not make it a hybrid Quote
Lew91 Posted January 15, 2013 Posted January 15, 2013 The word "hybrid" means a mixture of two or more elements to make one thing. This has been open up and polished which are two separate processes making the one object different. Therefore it is hybrid but not as you all presumed.If that's the case I'm going to take mine apart and make mine a hybrid tomorrow but mines going to be shinier then yours looool Quote
Dan B Posted January 15, 2013 Posted January 15, 2013 So it's a hybrid of a td04 and a tube of autosol Quote
