Ep91Ben Posted February 12, 2013 Posted February 12, 2013 As said what size do I get ill be running standard internals on a td04 ? Help appreciated Thanks Ben Quote
Ep91Ben Posted February 13, 2013 Author Posted February 13, 2013 because trd do a 0.6 mm one but I don't know what one to use Quote
Amjad Posted February 13, 2013 Posted February 13, 2013 1.2mm is standard I think just go with that Quote
Idrees Posted February 13, 2013 Posted February 13, 2013 because trd do a 0.6 mm one but I don't know what one to use I wouldn't recommend using that on a turbo application, you'll regret it. Do a search on TGTT, 'Sigma' used one a long time ago (regardless of being advised not to) and it barely lasted. Quote
Rob H@RCH Engineering Posted February 13, 2013 Posted February 13, 2013 I use a TRD 0.6 gasket on mine there very good gaskets BUT I am running low comp pistons so the TRD one balances it out nicely, I would not recommend one with stock internals as this would raise the comp too much. Id go for a 1.2mm at least with a TD04. Quote
Ep91Ben Posted February 13, 2013 Author Posted February 13, 2013 Okay looks like im going to go with a 1.2mm then Quote
Ashstarlet200 Posted February 17, 2013 Posted February 17, 2013 Ep91 ben ive named and shamed you mate in the club member chat room. I will see you around one dayOkay looks like im going to go with a 1.2mm then Quote
daniel_g Posted February 17, 2013 Posted February 17, 2013 What happened bud ? Sorry to hear that. Quote
Ashstarlet200 Posted February 17, 2013 Posted February 17, 2013 Ben likes to sell you something. Then not sending you the item then tells you hes going to sed you your money back....then never does Quote
JordanEP91 Posted February 26, 2013 Posted February 26, 2013 Ben likes to sell you something. Then not sending you the item then tells you hes going to sed you your money back....then never does I have heard the same thing!! A new lad comes on the forum and you rip him off, no one should get ripped off, you wouldn't like it done to you so why do it to other people, the only thing you deserve is to get your head ripped off, there's always one, you have done it to a number of people!! Have a custon headgasket built for your car it won't matter about the cost because you will be getting it for free because you will be using the money that you got off those lads you robbed!! SCUM!! Quote
