Stevo_n Posted February 13, 2013 Posted February 13, 2013 As above, what size brakes will fit under 15" wheels ET38? Its about all the data i have at minute.Want a 4 pot caliper with floating discs if possible. Quote
Keri-WMS Posted February 13, 2013 Posted February 13, 2013 If you look in our WMS trader section we've got downloadable/printable templates you can use to see if our 4-pot kits fit. Chances are the 275x22 or 277x25 kits will fit, not very likely the 295x26 one will though - but you never know! Quote
Stevo_n Posted February 13, 2013 Author Posted February 13, 2013 If you look in our WMS trader section we've got downloadable/printable templates you can use to see if our 4-pot kits fit. Chances are the 275x22 or 277x25 kits will fit, not very likely the 295x26 one will though - but you never know! Thanks i will have a look, are the 275 and 277 a floating disc? Could you pm some prices for kits? Thanks Steve Quote
WallaceGlanza Posted February 13, 2013 Posted February 13, 2013 I run 288mm hi spec 2 piece discs with wilwood calipers behind 15" rays - I did manage to fit 300mm discs behind my 15" TSW's too... Quote
Stevo_n Posted February 13, 2013 Author Posted February 13, 2013 I run 288mm hi spec 2 piece discs with wilwood calipers behind 15" rays - I did manage to fit 300mm discs behind my 15" TSW's too... Should be plenty there 288 on a light car. Should'nt be doin track work but want decent stoppers. Thanks for info. Steve Quote
morgey Posted February 13, 2013 Posted February 13, 2013 I've got the 277x25 wms kit, stopping powers brilliant, massive upgrade from 256 glanza brakes.More than good enough for the road Quote
Keri-WMS Posted February 13, 2013 Posted February 13, 2013 Thanks i will have a look, are the 275 and 277 a floating disc? Could you pm some prices for kits? Thanks Steve Sure, I'll send you a PM - you can see prices here too (pick the 55mm or 54mm hubs): http://www.ukstarletowners.com/forum/234-wms-brakes/ Discs with the kits are one-peice, but we're planning to launch rotor/bell discs in the future as a retor-fit upgrade/option for the kits. Quote
Liam_D Posted February 15, 2013 Posted February 15, 2013 I've got the 277x25 wms kit, stopping powers brilliant, massive upgrade from 256 glanza brakes.More than good enough for the roadThis! I run the exact same kit and the stopping power is awesome. Quote
