Glanza AuA Posted February 20, 2013 Posted February 20, 2013 (edited) this has been killing me for almost a year now, especially because im a person who like everything to run nice and smooth on my V OK here it go's Both my RAD pipes go hard as soon once it reaches op temp im also having constant tiny bubbles when i take my rad cap off with is diffidently not normal! things that i have done to diagnose this problem: 1 changed HG twice with arp bolt once2 head got skimmed3 new thermostat 4 new Civic type RAD5 proper cooling bleeding6 lower pressure CAP 0.9 bar7 comp test 170 170 170 160 now all some folks have told me is, if im not having no oil water mix, no overheating no overflow in tank,should i just forget about it??? BUT I CANT!!because this is a sign of my cooling system not running like it should im thinking this is a cracked head!! i have still not done the block tester leak thing because here in Aruba is hard to know someone who has that and also our stores don't sell them so my fav to ask is could someone go outside for a ride in there V or GT once you reach OP tempcould you give you RAD pipes a squeeze and feel it both pipes are hard ??? really want to know if this is normal and pls give me all the info of what you guys think my problem is?? thanks a lot guy i will appreciate this Edited February 21, 2013 by Glanza AuA Quote
Glanza AuA Posted February 20, 2013 Author Posted February 20, 2013 bumpy guys would like to know Quote
Asad Posted February 20, 2013 Posted February 20, 2013 top one should be hard + very hot while the bottom one is cool and soft..... when the stat opens the bottom one gets hot and harder....cant remember what the top one is like when the stat is open been a while since i messed with a starlet you want as higher pressure rad cap as you can get certainly not lower than standard, higher pressure increases the boiling temp of water.... Quote
Glanza AuA Posted February 20, 2013 Author Posted February 20, 2013 higher pressure cap ?? wouldn't that cause more pressure as in even more harder pipes?? Quote
Glanza AuA Posted February 20, 2013 Author Posted February 20, 2013 i know the upper one gets hard first,once the thermo opens lower one also go's hard Quote
Asad Posted February 20, 2013 Posted February 20, 2013 (edited) yes but not enough to do any harm ^ thats normal nothing to worry about Edited February 20, 2013 by Asad Quote
Glanza AuA Posted February 20, 2013 Author Posted February 20, 2013 everything else checks out,but why is there constant tiny bubbles coming in my RAD ??and is it really normal for the pipes to get so hard ?? still dont get it Quote
akyakapotter Posted February 21, 2013 Posted February 21, 2013 Think you'll get a better reply tomorrow bud ever one is sleeping now as is nearly 1am. mine is rock hard but that's cause some thing is wrong that I'm trying to get to the bottom of when I finish work at 5am lol Quote
Glanza AuA Posted February 21, 2013 Author Posted February 21, 2013 ohh my god!! i forgot about the time differences lol thx akyapotter Quote
Glanza AuA Posted February 21, 2013 Author Posted February 21, 2013 its like 9:03pm here in aruba now Quote
akyakapotter Posted February 21, 2013 Posted February 21, 2013 its like 9:03pm here in aruba now Only people you'll get on this time of night is the night shift lot lol Quote
akyakapotter Posted February 21, 2013 Posted February 21, 2013 (edited) Haha got itIt's 4:15am here now lol Edited February 21, 2013 by akyakapotter Quote
pick1 Posted February 21, 2013 Posted February 21, 2013 At optimun temp the rad pipes should go hard I believe with the pressure in the cooling system but then should start to soften up when cooling down or not under load as far as believe and with what u have already changed and checked think u have pretty much done everything I can think off does your expansion tank ever over flow / steam Quote
Glanza AuA Posted February 21, 2013 Author Posted February 21, 2013 hi mate and no my exp tank does not overflow in anyway it does the normal suck in and out procces with is normal,but the pipes just stay constant hard Quote
DanGEP91 Posted February 21, 2013 Posted February 21, 2013 If the car runs smooth and it's not causing any problems, you may not work it out until/if it gets worse and the 'problem' becomes more obvious. You know what they say, 'don't fix it if it ain't broken!' Keep an eye on it mate and see what happens. Just to let you know though I take no responsibility if I'm advising you not to take action over a problem, I'm not a mechanic after all haha Quote
Glanza AuA Posted February 21, 2013 Author Posted February 21, 2013 haha i know what you mean mate and thx for the advice but i just cant let it go its either a cracked head or im just loosing my mind Quote
Glanza AuA Posted February 21, 2013 Author Posted February 21, 2013 could anyone give a squeeze on there's ?? Quote
turbo Grant Posted February 21, 2013 Posted February 21, 2013 Does sound like a cracked head. As when it gets warm the crack will open up. Have you tryed re torquing your head bolts now you have do some miles Quote
Glanza AuA Posted February 21, 2013 Author Posted February 21, 2013 re torquing?? it was so scary doing the last 90 degree so i need to give it more torgue now ? Quote
Glanza AuA Posted February 21, 2013 Author Posted February 21, 2013 http://s1100.beta.photobucket.com/user/angeleau/media/IMG_0368_zpsddcca282.mp4.html what do you guys think ? Quote
