Jim* Posted February 21, 2013 Posted February 21, 2013 So I'm going to flush my heater matrix tomorrow see if I can get my heaters a bit hotter! Just wanted to know when I remove the two pipes going into the bulkhead, do i put a hosepipe into the bulkhead side or the engine side? and do I remove both then put hosepipe in or do just one at a time? Cheers Quote
rmsnoel Posted February 21, 2013 Posted February 21, 2013 Remove both sides man. Although please be careful because the pipes are very soft and easily squashed. Quote
rmsnoel Posted February 21, 2013 Posted February 21, 2013 You remove the clamps with pliers and when gently twist the hoses by hand to break the seal and they should slide off handy. Use your hands and not the pliers. And don't turn the garden hose on full blast either. Is your blower motor workin ok, does it get better when you change it to recirculate air inside the car. Is your pollen filters blocked and does your hot cold flap fully close when you want it to? Quote
Jim* Posted February 22, 2013 Author Posted February 22, 2013 No it dosent change apart from making a funny noise when I change I to inside the car and the hot cold flap dosent really close either I don't think Quote
Socks Posted February 22, 2013 Posted February 22, 2013 Flush it both ways..... you will see a shit load of crap come out... De-Scaling stuff used for cleaning dishwashers works wonders.... Quote
Jdmasfuck Posted February 22, 2013 Posted February 22, 2013 im trying this on sunday , but staying away from using chemicals in there because i heard it can damage certain seals and stuff in an around there so not worth the risk water will suffice for me !! Quote
james@cjperformance Posted February 22, 2013 Posted February 22, 2013 if you have access to an airline it works even better Quote
rmsnoel Posted February 22, 2013 Posted February 22, 2013 Jim, are your heater controls knobs or the pushbutton type. You can adjust the flaps where the cable attachs. Id check that first before flushing it out.Im sure dishwasher descaler wouldnt do any harm man but like u say a good rinse out with a hose should be ok Quote
Jdmasfuck Posted February 24, 2013 Posted February 24, 2013 Feckin hell tries flushing the matrix out and failed miserably due to the fact that the pipes would not budge at all I obviously used some mold grips to loosen the ring thing Then I gave up n ran inside like a bitch because it was cold !! Quote
morgey Posted February 24, 2013 Posted February 24, 2013 Hahahahaha man up you girl You prob want some slider grips to loosly grip the pipes to twist the pipes to break the seal, but not to tight as you could bend, crush or maybe break the pipes into the matrix.If youve got some maybe try some penetrating oil under the pipes if you can get to it, leave it for a lil while and it might work into the scum and loosen up the pipes a bit Quote
aaddzz123 Posted February 24, 2013 Posted February 24, 2013 Done this a few times now. Take both pipes off and stick your hose inside. Standard hose size fits in nice and tight. Both times I did mine, had clean water going one way and looooads of crap come out the other way. Makes a pretty big difference but feel like mine needs doing yet again and I only did it a few months ago. Probably better to flush the matrix with clean water and then run a proper flush through the whole system. Quote
