hey guys and gals, just joined up and thought i'd say hello :unsure: there's some very nice ep's on here :D
i recognise a few names off TGTT where i'm usually found.
anyway here's a couple of pics of my starbo, which i'm still rebuilding lol
hope you like :lol:
Tom.
very nice gt are you not on the austarletclub, and did you not have a big end bearing come through the block or something like that,remember seeing the photos awesome work mate.
thanks for all the comments peeps and sorry for posting in the wrong section shelly :unsure: i should know better really lol
@ sparky, it's one of sacha's td04 kits, but i ditched the turbo to go for a bigger one as the td04 wouldn't give me the power i'm after :D
here's the spec for anyone who's interested
spec:
engine
75mm ross pistons
pauter rods
1.45mm headgasket
new main and big end bearings
all new oil seals throughout
lightweight bottom pully
new starter motor
550cc injectors
oil catch can
apexi power filter
GReddy/ Trust oil cooler with filter relocator
sard thermostat
samco coolant hoses
tdo**** turbo(i'll spill the beans once i've dyno tested it :lol:)
wepr td04l manifold and downpipe
wepr fmic
wepr dual core rad
tial 38mm w/g and dump pipe
toytuning rad cooling panel
magnacore ht leads
hgk iridium plugs (heat range 8)
ajusa headbolts
lightweight flywheel
new engine backing plate
full gearbox rebuild + trd helical diff
and alot more i've prob forgot lol
electrics
GReddy emanage ultimate (c/w support tool, injector, ignition and map sensor harness, 3 bar map sensor and knock sensor adapter)
GReddy egt guage
GReddy boost guage
apexi avcr
apexi power stabiliser
custom made electronic fan controller
kenwood headunit and front speakers
plasma dial kit
wheels/handling/braking
sparco racing rims (15")
eagle f1 tyres
trd coilovers
tein adjustable top mounts
cusco rear strut brace
cusco lower arm bar
cusco side bars
cusco bmcs
whiteline front upper strut brace
rsr panhard rod
custom made anti-lift plates
braided brake hoses all round
levin calipers on the front
corolla front discs
mr2 turbo front pads
standard rear discs and pads
new bmc
whiteline front and rear anti-roll bars
zep "c" pillar bar
new bottom ball joints
new track rod ends
exterior
front bumper cut and meshed
reverse scoop
zep fenders
custom corner splitters
interior
rear completely stripped
carpet and sound deadening removed from the front and replaced with acoustic carpet
starlet armrest
cruise gear knob
momo steering wheel
3 point harnesses one both front seats
i think thats the lot :lol:
hi mate you do most the work your self or buy it like it?
impressive list mate ;)
hi mate, so far the only work i had done for me was the machine work on the block, everything else is me B)
