mini1.3 Posted February 23, 2013 Posted February 23, 2013 (edited) RIght normal h4 bulbs work fitted HID kit that i got off here andPassanger side bulb lights up for 1 minute then cuts out. Side lights workHigh beam worksJust dipped beam on passenger side Replaced the ballast and bulbs just cant get it working Edited February 23, 2013 by mini1.3 Quote
jellybaby Posted February 23, 2013 Posted February 23, 2013 Earth as I had a prob like that turned out to be a bad earth Quote
jackkelly Posted February 23, 2013 Posted February 23, 2013 Sounds like an earth, if it's passenger side earth it straight to the battery, worked fine for me Quote
Amjad Posted February 23, 2013 Posted February 23, 2013 Would it be an earthing problem too if the full beam didn't work on one side of the HID? Quote
mini1.3 Posted February 23, 2013 Author Posted February 23, 2013 should I earth the before bulb plug or the hid kit Quote
TurboTobz Posted February 23, 2013 Posted February 23, 2013 Had this with my mates earthing wasn't perfect all the black wires should be bolted down onto metal surfacing, ensuring the contact of the earth sits on clean in painted metalAmjad try the bulb in the other ballast see if that works Quote
Amjad Posted February 23, 2013 Posted February 23, 2013 Nice one! I took them off a while back but I'll give it a go! Quote
