The actual banjo just needs to be an M12 - the thread doesn't matter (there is no thread on the banjo just a through hole). So the one you linked would be fine but you just need a different banjo bolt.
Edited by WallaceGlanza
good plan ill just go ahead with that but need to kno if the race tech water lines are 6mm as thats for 6mm hoses...
Edited by iamlegend
The race tech lines come with the banjo's fitted to hose so it's just the bolts you need..... http://www.race-tech.net/index.php?main_page=product_info&cPath=2_6&products_id=35
I could make this simple for you by flogging you the 2 water line banjo bolts and one oil line banjo bolt (plus copper washers) as I have the lot here. :p
Or http://www.ebay.co.uk/itm/M10-x-1-5-Banjo-Bolts-With-2-Washer-For-Car-Motorcyles-/280568650948?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item415331dcc4
Plus
http://www.ebay.co.uk/itm/M12-BANJO-BOLTS-FOR-12MM-BRAKE-LINE-MOTORCYCLE-BANJO-BOLT-COPPER-WASHERS-/280744800162?pt=UK_SportingGoods_OtherSports&var=&hash=item415db1afa2
Same seller, 8 quid, sorted.
I've got 2 racetech water lines you have have bud... Paid like £115 for them ffs (livid). But yeah if you're interested PM me.
1 line is split, and leaked coolent. The other is fine. But both have the correct bolts for td04.
