Scoobysvx Posted June 9, 2015 Posted June 9, 2015 Looks nice jay, you keeping the splitter black? Quote
jayc-glanza17 Posted June 9, 2015 Author Posted June 9, 2015 Yh jack..Its going get chipped on track being so low so no point in spending money on paint.lol. Quote
Scoobysvx Posted June 9, 2015 Posted June 9, 2015 Aha fair enough mate, when's your next track time? Quote
jayc-glanza17 Posted June 10, 2015 Author Posted June 10, 2015 Tuner fest at brands is next track session jack. Quote
Scoobysvx Posted June 10, 2015 Posted June 10, 2015 Drop me a text near the time, I'll come and watch you if I can make it 👍 Quote
jayc-glanza17 Posted July 5, 2015 Author Posted July 5, 2015 So tunerfest at brands hatch happened.Brilliant weather, car did excellent.Got past my pals evo and few other pals from local club.Really was a cracking day and my glanza didnt miss a beat.i played with tyre pressures and dropped them to 18 on the front and 22 on the rear.And they did well much better then a month before at lydden (cant quite yet afford track tyres).Anyways here are some pictures from people from the stand i was on.gtr was mental. Spoke to the guy its pushing just over 700bhp. Quote
jayc-glanza17 Posted July 5, 2015 Author Posted July 5, 2015 Cheers bro.Ive got silverstone in between now and then. Quote
AdamB Posted July 5, 2015 Posted July 5, 2015 Still looking good Jay!What tyres are you running at the moment then? Tyre pressures are very low and interesting way that you've gone lower at the front than the rear. Did you not find the front end washing out with flexing the sidewalls? Quote
jayc-glanza17 Posted July 6, 2015 Author Posted July 6, 2015 Shitty t1rs adam..Personally i run front lower as i did at least 12 laps maybe 14..And when checked the pressure it was 24 front and 25 rear.So after few laps the sidewalls didnt flex as much as lydden.Spoke to a instructor their and he said run those tyres at those pressure,So went with his reccomendations and was a vast improvemnt.And i use the back end sliding to dpget front tucked in adam.But saving for ns2r or ad08r as need a stiffer sidewall and more grip in tractions terms and i will gain a huge amount.Cheers tho buddy you coming brands on 23rd? Quote
Bussey Posted July 6, 2015 Posted July 6, 2015 Shitty t1rs adam..Personally i run front lower as i did at least 12 laps maybe 14..And when checked the pressure it was 24 front and 25 rear.So after few laps the sidewalls didnt flex as much as lydden.Spoke to a instructor their and he said run those tyres at those pressure,So went with his reccomendations and was a vast improvemnt.And i use the back end sliding to dpget front tucked in adam.But saving for ns2r or ad08r as need a stiffer sidewall and more grip in tractions terms and i will gain a huge amount.Cheers tho buddy you coming brands on 23rd?Jesus Christ, T1Rs have mega soft sidewalls at 32psi, 24 psi must be like driving a boat Quote
Amjad Posted July 7, 2015 Posted July 7, 2015 NS2R are very stiff I've always been advised to run higher pressures at rear too, I thought that was the norm? Quote
AdamB Posted July 7, 2015 Posted July 7, 2015 Shitty t1rs adam..Personally i run front lower as i did at least 12 laps maybe 14..And when checked the pressure it was 24 front and 25 rear.So after few laps the sidewalls didnt flex as much as lydden.Spoke to a instructor their and he said run those tyres at those pressure,So went with his reccomendations and was a vast improvemnt.And i use the back end sliding to dpget front tucked in adam.But saving for ns2r or ad08r as need a stiffer sidewall and more grip in tractions terms and i will gain a huge amount.Cheers tho buddy you coming brands on 23rd?Those hot pressures still seem pretty low lol. As long as you got on alright with them though is the main thing.I'm in a mad rush to get my car done and ready to get back out asap, but I'm not 100% confident I'm gonna make it with work in the way and everything NS2R are very stiff I've always been advised to run higher pressures at rear too, I thought that was the norm?I tend to run lower pressure in the rear than the front, purely because there's less weight at the rear (fwd), the lower pressure helps create more friction and helps keep the tyres upto temp better. Plus the higher front pressure keeps a sharp turn in.Everyone drives different though, just a case of experimenting, I found with the NS2-R's that I like approx 4psi hot increase in the front Vs rear pressures. Quote
Amjad Posted July 7, 2015 Posted July 7, 2015 Ah great you run them too! The tyres are new to me so I haven't used them on track. Pressures I mentioned earlier were for rainsports (very soft) I wonder having rear camber would make any difference with regards to what pressure is best to run Quote
AdamB Posted July 7, 2015 Posted July 7, 2015 I use them on my Civic, tyres start getting expensive when you go to some proper sized tyres haha, so can't grudge paying £200 per corner for AD08's or R888.A little camber helps with lateral force from the tyres, but doesn't generate a great deal more heat. Weight is a big influential factor, so is spring rate Quote
Amjad Posted July 8, 2015 Posted July 8, 2015 Likewise, £200 for a set of stiff grippy tyres is a great deal! Thanks for the advice! Jay I'm sure you'll like the ones you've mentioned, bang for buck the Nankang are hard to beat Quote
jayc-glanza17 Posted July 8, 2015 Author Posted July 8, 2015 Thanks adam and amjad little debate,haha..But nankangs are going to be orderd. If i get the money from a pal he owes me,Then nankangs will get orderd.. Have either of you tried the 120 or 180 compound? Quote
Amjad Posted July 8, 2015 Posted July 8, 2015 You'll notice the step up straight away! I went for the 180, chased up lots of feedback on them and they were the ones that were recommended more Quote
Bussey Posted July 8, 2015 Posted July 8, 2015 180s are the one, you will kill a set of 120s so quick Quote
AdamB Posted July 9, 2015 Posted July 9, 2015 (edited) I'd recommend the 120's mate, the cars too light and could run with the softer compound. I run 180's, had 1 trackday and 10k road miles so far, still about 2.5mm'ish of tread left. Or if you want to be clever, 180's on the front and 120's on the back, might provide a better balance and less faffing with tyre pressures. Edited July 9, 2015 by AdamB Quote
jayc-glanza17 Posted July 10, 2015 Author Posted July 10, 2015 Interesting adam..I was thinking grab 180s..Then get a different set of wheels over winter purely as a track set.. Quote
AdamB Posted July 10, 2015 Posted July 10, 2015 The only downside to running two different compounds would be you wouldn't be able to rotate them. Depends how many road miles you cover really. Could always get the 180's for now, then when you get track wheels bung a set of 120's on them, their cheap enough to do so plus will give you a good comparison. Quote
jayc-glanza17 Posted July 14, 2015 Author Posted July 14, 2015 Nankang ns2rs 180 compound are orderd guys.hope to have these fitted before 23rd july track evening.. Quote
