monty1991 Posted March 17, 2013 Posted March 17, 2013 workin on a mates v he bought with abs problems. thought it would be an easy fix! ho wrong where we! check codes at the start got 31 and 32. left an right front speed sensor so got 2 second hand abs sensors. fitted ok. cleared faults went for test drive an get fault 31 right front speed sensor. but if we got a few mile run we get both faults back.. wires look ok an rings look fine. what else could it be? very tempted to rip it all out! Quote
monty1991 Posted March 17, 2013 Author Posted March 17, 2013 ano but is ther any common problems/fixes lol Quote
rmsnoel Posted March 17, 2013 Posted March 17, 2013 Unplug abs relay and problem solved. Abs will try to kill u in the wet.I eould check the wires from the sensors and xlean the sensor rings on the driveshafts with brake cleaner/toothbrush Quote
monty1991 Posted March 18, 2013 Author Posted March 18, 2013 rings seem fine.. its for mot thats why we wanted to fix it. gonna buy the parts to remove it this weekend Quote
jellybaby Posted March 18, 2013 Posted March 18, 2013 rings seem fine.. its for mot thats why we wanted to fix it. gonna buy the parts to remove it this weekendI posted the part numbers u need in the nifty part number section on here Quote
