Sefton-EP91 Posted March 19, 2013 Posted March 19, 2013 Can I run this setup or would the wideband not pick up the correct readings? Quote
Sefton-EP91 Posted March 19, 2013 Author Posted March 19, 2013 Wasn't sure because I was assuming the wide band needs all the exhaust gases to give me a accurate reading.. Must be me acting thick lol Quote
russ78 Posted March 19, 2013 Posted March 19, 2013 I don't think its to do with quantity of the gases more the mixture of the gases if im not mistaken Quote
Sefton-EP91 Posted March 19, 2013 Author Posted March 19, 2013 Oh right thanks lads one screamer on order then! Quote
AdamB Posted March 19, 2013 Posted March 19, 2013 A wideband is usually located way after the manifold/downpipe anyway, so you won't have a problem Quote
Sefton-EP91 Posted March 20, 2013 Author Posted March 20, 2013 glad i got that covered screamer pipe will be ordered then Quote
