alan.h Posted March 28, 2013 Posted March 28, 2013 When i drive my Glanza on full boost the engine light comes on, any ideas? It never happens when on low boost, just on full boost when i reach around 5k rpm Quote
TrisK Posted March 28, 2013 Posted March 28, 2013 Do a fault code reading mate and it'll give you the code?What are you boosting at? Quote
akyakapotter Posted March 28, 2013 Posted March 28, 2013 Fuel cut bud you have any kind of management or FCD Quote
StuDoc 72 Posted March 28, 2013 Posted March 28, 2013 Fuel cut bud you have any kind of management or FCD ^^ This Quote
hughes21 Posted March 28, 2013 Posted March 28, 2013 Could be knock sensor code 52 just changed mine as the light was flashing up wen going over 3k into boost Quote
Matt1878 Posted March 28, 2013 Posted March 28, 2013 Fuel cut!!! mine used to do it all the time Quote
AlancEP82 Posted March 28, 2013 Posted March 28, 2013 if your boostin or creeping up to .85 its fuel cut as all the lads are saying Quote
alan.h Posted March 29, 2013 Author Posted March 29, 2013 how do i check fault code? i have diagnostic tool but dunno is there one on glanzas boosting standard i think Quote
Jamie1st Posted March 29, 2013 Posted March 29, 2013 Bridge te1 and t1 (double check) on your diagnostic port, this will then give you a flashing sequence on the engine management light. (For example,. Flash Flash Flash.... Flash Flash................Flash Flash...Flash Flash Flash.........) That would mean 32 and 23. Quote
