sylwek Posted April 9, 2013 Share Posted April 9, 2013 hello i have springs -40mm in my glanza 16" et35 with tires 205/40 will be ok? or better 15' et35 with tires 205/45 ? Maybe some other suggestions on the other ET? sorry for my english thanks Sylwek Quote Link to post Share on other sites
rmsnoel Posted April 11, 2013 Share Posted April 11, 2013 The normal size is 15x6.5 et38This is the common alloy wheel size with 195_45_15 or 195_50_15 tyresWith other sizes you might need a 'adjustable panhard rod' or carry no fat chicks Quote Link to post Share on other sites
sylwek Posted April 12, 2013 Author Share Posted April 12, 2013 ok great thanks mate Quote Link to post Share on other sites
Liam_D Posted April 12, 2013 Share Posted April 12, 2013 <<< Need more pics of the Pulsar Quote Link to post Share on other sites
sylwek Posted April 13, 2013 Author Share Posted April 13, 2013 http://nissanzone.pl/viewtopic.php?t=10782 Quote Link to post Share on other sites
whitestar Posted April 19, 2013 Share Posted April 19, 2013 (edited) I have 16x7.5" ET35 rims and 195/40 tires and they do not rub at all. I don't have a panhard rod. I had 205/45/16 on my NA starlet back in the days and it was pulling quite alot if there was worn grooves on the road. I'd really recommend to have max 195 tires if you're having it as a daily driver (you can get wider drag tires for the strip if needed ). I don't know about your roads in poland but our roads have quite bad grooves on the roads as it's quite common to use studded tires in the winter time. Edited April 19, 2013 by whitestar Quote Link to post Share on other sites
Amjad Posted April 19, 2013 Share Posted April 19, 2013 Use the 15s with 195 tyres Quote Link to post Share on other sites
sylwek Posted April 19, 2013 Author Share Posted April 19, 2013 will use 15' 195 /50 tyres Quote Link to post Share on other sites
