Gav_kara Posted April 14, 2013 Posted April 14, 2013 Ok my car started smoking on idle when hot posted up everyone said turbo seals which I was thinking so I bought a speedvision off a member on here so I fitted it today and smoke is even worse but seller said it was fine what's people option. It smokes on boost and then on idle when hot if ya leave it a while then blip it a couple of times puffs of smoke blue smoke and smell of burning oil Quote
steve-gers Posted April 14, 2013 Posted April 14, 2013 Maybe turbo you bought was also knackered. Did you check it before you stuck it on? Quote
WallaceGlanza Posted April 14, 2013 Posted April 14, 2013 You may just have residual oil left over in the exhaust - did you clean it out at all? Quote
Liam_D Posted April 14, 2013 Posted April 14, 2013 You may just have residual oil left over in the exhaust - did you clean it out at all?This Quote
Amjad Posted April 14, 2013 Posted April 14, 2013 Think Rbz had this when seals went and then replaced the turbo. Took the exhaust off, poured petrol down it a few times to clear out the muck and all was well Quote
Beastmode panda Posted April 14, 2013 Posted April 14, 2013 Think Rbz had this when seals went and then replaced the turbo. Took the exhaust off, poured petrol down it a few times to clear out the muck and all was well Bingo! Exactly what I did. My oil seals went in my ct9 too, like amjad said. I got 2 buckets, got my pal to hold up the exhaust section and poured about 2 litres of petrol down the exhaust about 50 times bucket to bucket. The state of the water after was insane. quick blast up the motorway and job was a gooden! . Quote
Gav_kara Posted April 14, 2013 Author Posted April 14, 2013 Thing is when I dropped the decat pipe off there was no sign of oil round the exhaust turbine or waist gate area at all just sut and turbine a nice brown colour. With symptom being same I'm starting to think its more like head I.e valve stems. Going to comp test it tomoz after work and also a leak down test.. The tong ct9/12 hybrid I just took off I going to send to cr turbos who we deal with to have it checked as the turbo is so much better than the speedvision I put on today the differance between waist gate size so on is crazy.. Then ill sell the speedvision again. Quote
AdamB Posted April 14, 2013 Posted April 14, 2013 A comp or leak down test won't show where the problem lies, them tests are for showing where gas is escaping. You'll need to remove the manifold and look at the cylinder ports. Quote
Gav_kara Posted April 14, 2013 Author Posted April 14, 2013 Had exhaust manifold off today and no sign of oil in the ports on exhaust side Quote
