Not sure which section to post this in..
Basically i get alot of clutch judder which is making a knocking noise and feels horrible! What should i look at changing ? Also can bang when i change into the next gear and lift the clutch
Any suggestions on where to start?
Cheers dan
Exhaust knocking somewhere at a guess.
Also sounds like you might be getting a fair amount of engine movement, might be worth renewing your engine mounts or uprating to some TRD or poly bushes
Check the mounts are actually tight haha, seen lots of loose bolts on mounts and it causes the noise you described.
Also, i bought a box from the last owner of your car so its prob been off fairly recently.
