har-vey Posted May 6, 2013 Share Posted May 6, 2013 (edited) I've been looking all night and can't find what I was looking for. I am having 4 wheel alignment setup this week and I am not sure what is an ideal track setup, of course there is no perfect setup for every track but what do others run? The car is only used for track days and weekend fun. Not a daily. Any recommendations on what to go for and what to avoid? I was thinking around 2 degrees negative camber or is that too much? errs Edited May 6, 2013 by har-vey Quote Link to post Share on other sites
Amjad Posted May 7, 2013 Share Posted May 7, 2013 I run -1.2 camber, 0 toe, +ive castor (ALK allows adjustment of this) If it wasn't a daily I'd run a bit more camber but probably not as much as 2 for the sake of tyre wear lol Quote Link to post Share on other sites
har-vey Posted May 7, 2013 Author Share Posted May 7, 2013 Ahh ok, I've read a lot of people run around 1.2-1.5 but wanted to know y not to run anymore. Anyone with experience would be much appreciated Quote Link to post Share on other sites
Amjad Posted May 7, 2013 Share Posted May 7, 2013 Turn in will be better I assume, but tyre wear goes up Best to ask the people who mainly use their cars for track, a few members on here! Quote Link to post Share on other sites
AdamB Posted May 7, 2013 Share Posted May 7, 2013 If you run too much negative camber, you'll be fine going round corners, but there will be less tyre on the road when it comes to accelerating and braking. -1.5 seems to be ideal for a starlet from what I've heard. If the cars not used as a daily am sure you wouldn't mind a bit more tyre wear for a bit more cornering ability.Could go for a little toe out on the front, but not really needed. Castor varies, some people like it because of the increased steering response, some people don't like it. Quote Link to post Share on other sites
rmsnoel Posted May 7, 2013 Share Posted May 7, 2013 This has been covered alot recently but its0° toe or alittle toe out if you cant get it spot on1.5° -1.75° camber I would go 1.75 if most of the driving is below 80mphIf u have an adjustable panhard rod set the axle 5-10 mm in favour of the passenger side so when you compress the rear it does rub the drivers arch (only if u have rubbing issues)I havnt bothered with caster kit this time.You can tighten or loosen the front arb bushes to increase or decrease over and understeer but Id do that on trackday Quote Link to post Share on other sites
Liam_D Posted May 7, 2013 Share Posted May 7, 2013 Mines been fast road setup to my requirements I run neutral toe, and -1.5 camber. Castor was just left as it was fine at the time of adjusting Quote Link to post Share on other sites
har-vey Posted May 7, 2013 Author Share Posted May 7, 2013 So 0 toe front and back? And think I'll go -1.75 camber as I still want to put the power down. Quote Link to post Share on other sites
Chris_14a Posted May 10, 2013 Share Posted May 10, 2013 I run negative 2 camber but mine is only used for track but it will be having the settings changed before track again Quote Link to post Share on other sites
