bailey Posted May 29, 2013 Share Posted May 29, 2013 Well guys i pulled my engine out to replace my crankshaft oil seal and timing belt and found this copper washer jammed behind the oil filter/pump casting and block any ideas inner diameter 28.1mm and 32.1mm outer diameter. Quote Link to post Share on other sites
Whitenoize Posted May 29, 2013 Share Posted May 29, 2013 Is it one of the washers off the oil feed to the turbo maybe? Quote Link to post Share on other sites
turbo Grant Posted May 29, 2013 Share Posted May 29, 2013 Thats for the big bolts that goes through the middle of the oil filter housing Quote Link to post Share on other sites
Rob H@RCH Engineering Posted May 29, 2013 Share Posted May 29, 2013 Id say it was for the center bolt for the oil filter housing. I could be wrong but I think thats about the only thing that big. Quote Link to post Share on other sites
bailey Posted May 29, 2013 Author Share Posted May 29, 2013 Ok ill have a look tomorrow csnt say ive ever had it off other than when changing my oil filter but that doesnt involve undoing the large bolt you talk of. Quote Link to post Share on other sites
