Someone do the math
exhaust is pretty similar, wings must have been custom made to still have the door trim part. advans are 14's in the first pic and 15's in the next two i think. i can't work out whether it's a different shade of turquoise or not though.
i would have loved a blast in that n/a though.
Edited by Billy SR
Am with you Billy. Its still got a N/a rear bumper has it not ?
hacked up n/a/reflet bumper, BUT glanza boot. Certainly does look a different colour here, but speedhunters are just fancy camera geeks that wank over photoshop.
Edited by Billy SR
Ey? Expand.
It was a silver Glanza you can tell by the engine bay colour and OEM stickers still in place.
It's defo not that tropicana one, that ended up sky blue and never got finished as far as I can remember.
have kept about 300 animals horse in TD05 specification. It is not solved Ri how far extensible, but is still amateur. I'll leave to the imagination time.
And (82 for replacement put AT → MT) specification
Divided use of 4.1-4.3 final. The change to 1.5-way 10K TRD1.5WAYLSD initial 8K → Cusco. 4E breaks JAM high cam + Complete Cruise connecting rod and piston, TD05-14B turbine, SARD made by WG, dream exhaust manifold, JAM-made F intercooler, TRUST breaks 10-stage oil cooler, aluminum radiator, main 550cc injector, VPRO control, EVC-5, ADVANNCE low resistance alternator - Star (90A), SARD fuel pump made, fuel pressure adjustment REG,
Brembo caliper -, Arago shock-absorber, spring rate F12k ~ 14K R8K ~ 12K, TRD stabilizer, Tanabe under brace, Cusco modified roll center adjuster, rear lateral rod, bush relationship Furupiro retrofit, door opening spot full increase, bulkhead welding . Undercoat all removal, accelerator pedal effort UP.
FRP bonnet (JAM), FRP door (Cruise), Tomo own rear under de Fe and Min - Length - (Amemiya RX to 8 for width processing), dream processing F under panel, general-purpose GT wing → large (^ ^) /. 6-point capacity (fill-in-the-blank, lighter) JAM bumper, F canard, Cusco roll bar Riyahatchi processing. Interior removal. RECARO-SPG → BRIDE gigue Ⅲ Type-RLowmax. Sabelt 3 inches 4-point belt. (Oil temperature, water temperature, oil pressure, temperature Mission OIL) Defi additional meter
google translate lol.
