Think Morgey is correct with the knock sensor. The blue wire is actually a black in a blue sleeve with insulation inside the blue. The knock sensor is right under the inlet above the altenator but it can be a pain to find. But I'm sure it's that wire
best way to do it is lie underneath the car and as u look up, the sensor were that plugs into is under the inlet manifold,roughly inline with the 2nd inlet manifold pipe from the right.
its literally just over the top of wer the sump seals to the block
awesome thanks
got it plugged back in and took the car for a run, its running really lean on boost now, around 13afr
could it be because the timing would have been retarded with the sensor unplugged, and now that its back in the timing is back to normal/advanced?
ive unplugged the battery to reset the ecu, to see if that fixes it
Edit: took the car a run after resetting the ecu, afrs are much better now 11-12, car also seems alot smoother and pulls better off boost
Could this be a result of the more advance timing, or is it in my head?
Edited by Weyro
